New Topic New Reply
Author: Subject: Coolant pipes in chassis tubes
Simon
posted on 27/5/20 at 04:57 PM Reply With Quote
I am building mid engine Beetle and having started fabricating the trans tunnel (50mm box) am thinking that with coolant pipes, fuel lines, brake lines, wiring and shifter cables it might be a bit congested so was toying with the idea or running the coolant pipes (35mm id stainless) inside the box section.
Now, is my concern that the hot water pipe might cause the box section to expand/contract unfavourably reasonable or a bit ocd? Or should I run brake hoses, wiring and fuel line inside the box and keep the coolant pipes up centre of tunnel, which could be left open to elements at the bottom
harmchar
posted on 27/5/20 at 05:01 PM Reply With Quote
I personally wouldn't run anything in the chassis tubes. How you going to check the condition of anything you put in there. Only time you'll know there's an issue is when coolant starts pissing out the end of the tube.
Just a thought.
steve m
posted on 27/5/20 at 05:18 PM Reply With Quote
No one picked up on the point that Beetles are air cooled ?
I presume the OP is using a different water cooled engine than a 20hp Beetle engine
I can not see a problem with running coolant pipes in a tunnel, as long as they were clamped well in
and possibly insulated ?
If I was to consider this, I would use a constant uncut tube, with flexi hoses or similar at each end that would be serviceable
if required,
steve
smart51
posted on 27/5/20 at 05:35 PM Reply With Quote
The space inside a big box section is dead space, why not run something through it? I'd make sure you could get the coolant pipe out when the car is fully built but otherwise go for it.
russbost
posted on 27/5/20 at 06:18 PM Reply With Quote
we run main battery cable, clutch & brake hoses thro' the top tubes on the Furore, saves loads of faffing with clipping up & nothing to inspect. If I were going to run cooling pipes that way I'd want one solid aluminium pipe from front to rear & the ability to slide it in/out from either front or rear of tube once fully built, as long as you insulate it from vibration/chaffing inside the tube (we rubber grommet our pipes etc) then no reason not to.
The expansion due to heat in a coolant tube would be pretty irrelevant
posted on 27/5/20 at 07:34 PM Reply With Quote
if required,
steve [/quote
Modern Beetles are water cooled!
posted on 27/5/20 at 08:04 PM Reply With Quote
if required,
steve [/quote
Modern Beetles are Golfs in dappy outfits IMHO.
gremlin1234
posted on 27/5/20 at 08:46 PM Reply With Quote
as far as I remember, the 'RAC blue book' prohibits things inside chassis rails, since they can't be inspected. so you would not be able to join any race series
I found it
5.20.12. Not carry or pass any liquids or gases, other than air
at atmospheric pressure, in or through any tubes comprising
part of the chassis structure.
https://www.motorsportuk.org/wp-content/uploads/2019/11/Blue-Book-2020-2.pdf
coyoteboy
posted on 28/5/20 at 09:14 AM Reply With Quote
If I were planning on racing, I would not as I don't like the uninspectable nature of it.
In reality, I'm fine with the practicalities of it and so long as it's rubber-supported down its length it will likely be fine.
Assuming the chassis sees a 100C difference in temperature from one member to the next, you might be looking at ~1mm length change between any two members. In reality you're not likely to see the chassis tube get even close to that, so the thermal expansion will be tiny.
jollygreengiant
posted on 28/5/20 at 10:05 AM Reply With Quote
For SAFETY reasons I WOULD NOT run electrical in the same tube as FUEL, BRAKE FLUID or WATER.
JMHO
Simon
posted on 28/5/20 at 05:43 PM Reply With Quote
Will probably just be the coolant pipes in bottom two and wiring in one of top two. Fuel and brake lines can take their chances with the gear shift cables
MikeR
Contributor
Posts 8599
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 28/5/20 at 11:19 PM Reply With Quote
Chapman ran client in a tube in one race car. It rusted. It was then banned. I appreciate you will be in a tube inside a tube, but how will you know it's not leaking and rusting?
SteveWalker
posted on 29/5/20 at 12:28 AM Reply With Quote
A drain hole in the outside tube will tell you if there is a leak - often used in industrial and nuclear processes.
Simon
posted on 29/5/20 at 11:29 PM Reply With Quote
I'll be using stainless steel
posted on 30/5/20 at 04:37 PM Reply With Quote
Will stainless steel rust?
If it leaks, the water level will drop, easy to spot.
I'm voting it will be fine as long as there are no inaccessible joins.
Sam_68
posted on 30/5/20 at 06:09 PM Reply With Quote
Not one, several Lotus race cars ran coolant through their chassis tubes - all the Lotus 22, 23 and (I'm pretty sure) 24 models did it, for a start.
You can see the 'tails' for connecting the rubber coolant pipes that linked to the engine and radiator on this (replica) 23 chassis:
The tubes don't rust if you have antifreeze/rust inhibitor in the coolant, of course. Back in the day, you weren't allowed to use antifreeze in racing cars for fear of spillages making the track slippy.
Several spaceframe racers (including the 23 - note that there are 2 pairs of outlets front and rear) also used the chassis tubes to run oil through (which might be more useful for a Beetle engine), but the problem there was ensuring no contamination, if you blew the engine up.
In both cases, the trick is to ensure that the pipes that are carrying the fluids are one-piece and continuous, so that they don't leak if a weld cracks.
That aside, and racing rules notwithstanding, I don't think it's an entirely bad idea.
New Topic New Reply
