Author: Subject: FS Gas turbine jet engine project
tegwin
posted on 11/6/20 at 04:10 PM Reply With Quote
Here is a partially built gas turbine engine. The original plan was to get the gas producer up and running and then build a power turbine. Expected output was about 4S.H.P.
turbine
turbine
More photos here: https://www.dropbox.com/sh/r56hn7fybf6rt5w/AAAx7mQhrnWIEo4M4YQ_dmFea?dl=0
What better way to turn diesel into noise and smoke!
Designed to start on propane and then run on high pressure atomised diesel.
Combustion chamber built to match the giant turbo. Burner nozzles and jets fitted. Diesel fuel oil pump fitted, oil circulation pump fitted with cooler and filter block. Various guages installed.
I did all the heavy metal bashing and started plumbing it all together and then ended up working away for several years so haven't touched it since. It needs someone to go through it all and finish the piping. Its not overly complex!
There's probably the best part of £2,000 worth of parts here including:
Giant KK turbo
A lot of steel.
Ultra high pressure fuel pump and jet (this was £300 by itsself)
Omron fibre-optic RPM sensor
High power DC motors to drive the pumps
Oil cooler, tank, filter block etc.
Electric blower to start the engine.
Cooling fans
Assorted pipe connections, tubes, clips etc.
Engine and parts are located in Plymouth. I could arrange to move them to Bristol if that is easier to collect. Total weight around 25kg.
£300 for the lot.... nice cheap project if someone wants a challenge and has a desire to wee their neighbours off
[Edited on 11/6/20 by tegwin]
www.verticalhorizonsmedia.tv
steve m
posted on 11/6/20 at 05:41 PM Reply With Quote
Why not use it to heat up your new house ?
tegwin
posted on 11/6/20 at 06:34 PM Reply With Quote
Haha... I mean... thats a genius plan.... use heating oil and turn it into a combined heat/power/noise machine
SteveWalker
posted on 11/6/20 at 09:01 PM Reply With Quote
The last time I played with a gas turbine, it was an industrial RB-211, exhausting into a DR-61? power turbine and driving an 11kV, 3ph, 60hZ, 24MW generator - we were burning 120 litres a minute of red diesel!
tegwin
posted on 11/6/20 at 09:06 PM Reply With Quote
mmm meaty!
I started my career playing with the EJ200 trying to figure out why the back end kept melting..... turned out the pilots were banging the after burner from 0-100 too fast causing small explosions behind the burner injectors.... they were suitably re-educated.
JC
posted on 12/6/20 at 06:25 AM Reply With Quote
mmm meaty!
I blame the FADEC designers.....
Then again, if you ‘slammed’ the throttle on an old school engine like a Viper, then that was a sure path to a surge/compressor stall.
