Author: Subject: R1 Cooling - Routing Question
woodsy144
posted on 4/8/20 at 12:12 AM Reply With Quote
Hello,
I am setting up the routing design for the R1 engine.
Looking at the original design, on the RHS side of the radiator there are 2 inputs. Top one from the thermostat / top of engine (inlet), and a lower attachment from the oil cooler (oil cooler outlet hose).
I would like to see what people have done with this additional hose.
Help or advise would be great.
[Edited on 4/8/20 by woodsy144]
adithorp
posted on 4/8/20 at 06:35 AM Reply With Quote
Which year/version of R1?
Originally on my 5vy, I fed the oil cooler outlet into the radiator bottom hose (inlet). Partly because this was neater packaging and partly so it wasn't feeding hot coolant from the oil cooler back into the engine. It did mean the engine took longer to warm up but cooled better in higher temps/loads. Worked well for several years.
Eventually I fitted a tuned motor and changed to a separate oil cooler system.
http://jpsc.org.uk/forum/
woodsy144
posted on 4/8/20 at 07:06 AM Reply With Quote
Currently am building it using a 08 engine so a 4C8. but plan is to build a second vehicle with a 2011 engine.
If you have pictures (or links to some pics), it would be great.
TimC
posted on 4/8/20 at 10:41 AM Reply With Quote
Some have seemingly done better with temps but I think the majority who run the 4C8 motor (hard i.e. on track) have removed the interdependence between oil and water cooling.
I used one of these: http://www.gyrodynamics.net/products/oil-cooler-adaptor-yamaha-r1r6/
You can then plumb a straightforward in/out water route with the standard Yam bleed lines left in place.
Worth knowing that the 4C8 hard-pipe where the water enters the block points up/down depending on how you look at it whereas the 5VY points horizontally which aided packaging on my car.
woodsy144
posted on 9/8/20 at 05:52 AM Reply With Quote
Cool thanks for that. Had a look at the gyro product and pulled apart the cooler today. I might have a bit of a crack at making one. I'm building two cars so economy of scale.
Is this item people usually go for building with the R1 (just wondering if I get more made)
