Author: Subject: CVH Rotor drive shaft
stig2
posted on 6/8/20 at 07:46 AM Reply With Quote
Morning all.
Does anyone know where I may buy a sierra 1.8 CVH rotor arm drive shaft as I shown in the image.
Alternatively, is there a conversion to do away with the drive shaft.
Thanks for your help.
[img]https://www.bing.com/images/search?view=detailV2&ccid=e2FiW6CC&id=713E3EFFA22D70755DDF2FE99857860CAFFF979F&thid=OIP.e2FiW6CCkEJN-fTU1 BmgMgAAAA&mediaurl=https%3a%2f%2fwww.picclickimg.com%2fd%2fl400%2fpict%2f351999185120_%2fFord-Sierra-18-1800cc-CVH-Distributor-Rotor-Shaft.jpg& ;exph=300&expw=400&q=1649199&simid=607999100898706893&ck=61BFD0F8CA0B722F4ACD593A4E3D4FEA&selectedIndex=0&FORM=IRPRST&ajax hist=0[/img]
[img]http://[/img]
mikeb
posted on 6/8/20 at 12:10 PM Reply With Quote
I can't see the link
When i got my CVH running i ditched the stock ignition system and put a NODIZ ecu, really straightforward, relatively cheap compared to other systems but not cheap cheap.
stig2
posted on 6/8/20 at 12:29 PM Reply With Quote
Hello Mikeb
I think this links a better one.
https://www.picclickimg.com/d/l400/pict/351999185120_/Ford-Sierra-18-1800cc-CVH-Distributor-Rotor-Shaft.jpg
adithorp
posted on 6/8/20 at 02:28 PM Reply With Quote
I guess you've tried ford parts department (using the 7 digit finnis code in that picture)?
http://jpsc.org.uk/forum/
stig2
posted on 6/8/20 at 03:15 PM Reply With Quote
Yeah, pretty much none existant.
mikeb
posted on 6/8/20 at 04:17 PM Reply With Quote
I broke that when I was stripping my old engine, I was going for a different ECU anyway but did hear they are v hard to find
posted on 6/8/20 at 06:10 PM Reply With Quote
Timing belt tensioner for the 1.8 CVH were unavailable best part of 20 years ago , suspect because it was a relevantly small production engine that parts are scarce
stig2
posted on 7/8/20 at 12:45 PM Reply With Quote
Hi Mikeb.
What did you use as an alternative rotor arm drive.?
Cb750
posted on 7/8/20 at 01:13 PM Reply With Quote
One on ebay item 264787922628. Called a router shaft on there and looks expensive!
