Author: Subject: Pedal travel
fatherchuck53
posted on 9/8/20 at 04:23 AM Reply With Quote
Pedal travel
How much clutch pedal travel do you have? Latest build is R1 powered, hydraulic clutch for daily driver, I know not a good choice. Having problems getting a smooth start without lots of rpm's or almost killing it. suggestions?
AdamR20
posted on 9/8/20 at 05:02 AM Reply With Quote
Would normally aim for at least 70mm. Obviously the first 10mm or so of that will be 'dead' (does nothing).
You may need a smaller master cylinder or an adjustment of the pedal arm itself to change ratio.
fatherchuck53
posted on 9/8/20 at 08:53 PM Reply With Quote
I Changed the pivot point per your suggestion so I would have approximate 70mm pedal travel, had 45mm before. Test drove felt much better than seal on cylinder started leaking. My luck.
fatherchuck53
posted on 19/8/20 at 04:50 PM Reply With Quote
Replaced the leaking slave cylinder. Changing the pedal travel ratio from 45mm to approx. 70 has made a huge difference in drivability. Bad part though, wife has tried it and likes it also. Maybe if I promise to do the dishes and vacuum the carpets she'll let me drive once in a while.
