Author: Subject: List of useable engine and g/box combos
harmchar
posted on 27/9/20 at 07:17 PM Reply With Quote
Has anyone ever compiled a list of engine and g/box combos that are suitable for 7 type chassis cars?
A list with engine size, power, weight, configuration etc.
I haven't even finished my own Pinto powered project yet and I'm thinking of a post IVA engine swap. Just wondered if someone had compiled the list to help others that might be facing the dilemma of what works well, easy, works but with loads of work and what doesn't work at all.
Ugg10
posted on 27/9/20 at 08:03 PM Reply With Quote
Pinto to Duratec is the usual swap as the exhausts are on the same side (drivers), one less thing to bother about, Zetec is on the other. Iirc the s2000 Honda engine is on that side too plus the Zetec SE.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
mcerd1
posted on 28/9/20 at 05:52 AM Reply With Quote
Originally posted by harmchar
Has anyone ever compiled a list of engine and g/box combos that are suitable for 7 type chassis cars? .
It's be quicker to make a list of what hasn't been done
Not all chassis are the same in the first place and a lot of options will need some mods (some more extreme than others) but almost anything could be made to work....
There are less options for gearboxes that will fit easily in most chassis but that doesn't mean much if you use an adaptor to suit the engine of your choice - maybe a better way to look at it is which engine would you like then find out how much work it would take to fit it...
Most l4 engines should be fairly easy, but l5/l6 engines might be too long to fit easily, similarly some V engines can bit tight (often it's the heads/cam covers width)
Mind you if all you want it is a high power to weight then maybe bike engines are worth a look
