Author: Subject: Headlights for my locost for IVA
Deckman001
posted on 19/10/20 at 12:33 PM Reply With Quote
As in the title, I need a set of headlights suitable for IVA. Anyone got any lurking around before I have to buy a brand new set ?
Jason
Mr Whippy
posted on 19/10/20 at 02:12 PM Reply With Quote
I don't have any to sell you.
But I'd suggest you don't buy some cheap sealed beam units with the lens moulded into the glass as they often have dreadful light patterns. I think it's partly due to them being a copy of a copy etc. and the lens is just a poorly defined wobble in the glass. My landrover had these when I got it (made by Ring) and the pattern was a mess and I could hardly see anything at night. I switched to these crystal clear ones with the reflector in the mirror and wow what a difference. I shall be using these again on the 2b.
linky
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
Deckman001
posted on 19/10/20 at 02:23 PM Reply With Quote
Yeah good point, I have popped into CBS today to pick up some other bits and got a recommendation as to which headlights of theirs to buy which could sail through IVA. His reply was 7" black headlamp, HL181BK 35 each (42 inc vat).
So if no one has any lamps that i could use for my IVA then that's my next option. It is a shame though to have to put 7" lamps on there instead of my original 4" ones that failed.
Jason
Mr Whippy
posted on 19/10/20 at 02:47 PM Reply With Quote
I prefer the bigger 7 inch ones as it gives the car a face one of the reasons I don't like the black LED type lights
Johnmor
posted on 19/10/20 at 03:38 PM Reply With Quote
Hi
I use those 7" black for my first Viento
Set the beam up against my garage door after marking position using my daily driver, passed SVA with no comment
steve m
posted on 19/10/20 at 03:47 PM Reply With Quote
I agree with Mr Whippy. the 7" headlights on a 7 look IMHO so much better than the small ish ones, yet the small ones do look good on some non 7 styled cars like the F1 replicars etc
car man
posted on 19/10/20 at 04:46 PM Reply With Quote
u2u sent
Deckman001
posted on 19/10/20 at 05:12 PM Reply With Quote
Originally posted by car man
u2u sent
Cheers Paul, and replied to
Badger_McLetcher
posted on 21/10/20 at 09:52 AM Reply With Quote
I used these ones:
https://www.carbuilder.com/uk/5-34-complete-headlamp-black
Glued a bit of edge trim around the rim just to be sure; failed on alignment rather than anything else. A bit more expensive than the 7" ones, but closer to your original lights.
If dysfunction is a function, then I must be some kind of genius.
Deckman001
posted on 21/10/20 at 12:28 PM Reply With Quote
Hi all, ,I think via u2u's I have now sorted them.
Am hoping to arrange pick up in a week or so so will be trying to do everything else by then.
Cheers all.
Jason
James
posted on 22/10/20 at 11:25 AM Reply With Quote
I used 7" ones.
I couldn't believe how good the lighting was compared to my road cars!
View User's Profile View All Posts By User U2U Member   James 's Aim
Deckman001
posted on 22/10/20 at 12:58 PM Reply With Quote
Originally posted by James
I used 7" ones.
Cheers James, Am currently waiting for a delivery of Diodes to sort my Fog light issue, then I can get the car back to my garage man to sort the suspension/ self centering, weld in the chassis plate and reset my ignition so as to get lower emissions.
Then it's just the head lights and manufacturers plate to arrange, then i can try to re book the test.
Jason
