Author: Subject: Making an auxiliary air tank from an old LPG bottle.
tilly819
posted on 24/10/20 at 11:46 AM Reply With Quote
Hi all,
Here are my latest efforts in the workshop. Seems to be working well so far. Not blown myself up anyway...
Hope you enjoy the video.
Tilly.
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
jacko
posted on 24/10/20 at 03:31 PM Reply With Quote
Nice work
Can I say why you would need a second tank or is it because you do spraying
Graham
Mr Whippy
posted on 24/10/20 at 03:43 PM Reply With Quote
Sounds a great idea tbh, they are really well made and often just lying about. I used one to make a very powerful underseal sprayer with terrific results and only cost a few pounds to make.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
gremlin1234
posted on 24/10/20 at 07:52 PM Reply With Quote
I saw the headline for this post, and thought of two things,
1: mount it so it drains.
2: paint it so it doesn't look like a propane tank
thankfully you did both
indykid
posted on 24/10/20 at 08:44 PM Reply With Quote
I've just done similar with a 47kg cylinder. I opted to weld a boss in the bottom as having filled the bottle with water to purge it, I found the boss for the valve protrudes into the cylinder and trapped water so it would never fully drain.
I see you've put a ball valve on to isolate the cylinder, but do you still have a pressure relief valve? The calor bottles have a 26bar PRV built into the valve body but as I've junked the original valve body, I've put a 10bar valve in a T to mitigate the risk of explosion in a fire. The bottle thread is 3/4 BSP should you want to use pipe fittings if you do another one.
How do you find the smell of the air after it's been in the propane bottle? I haven't used my 47kg cylinder in anger yet, but the 19kg one I did before still had enough stenchant in it to make the air smell bad for quite a while. I chucked some gravel in this big one and rolled it round the lawn for a bit so I'm hoping it's not quite so pungent.
me? ambivalent? well, yes and no
v8kid
posted on 25/10/20 at 03:08 PM Reply With Quote
Nice Video as usual.
For others copying this project the thread in the propane tank is a standard BSPT thread and it costs only a couple of quid for a BSPT to compression adaptor from toolstation/screwfix and saves you a lot of machining plus having a larger bore. IIRC 22mm pipe has a higher burst pressure than 15mm. Also I find thread sealing fluid is more reliable than PTFE tape.
Is the polythene tube connector OK? I can't be arsed googling it but I guess you've done the homework.
In the past I used a similar technique to make a vacuum chamber to suck oil out of dry sump tanks - any other uses for old propane tanks apart from heaters that is
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   v8kid 's Aim
Simon
posted on 26/10/20 at 11:05 PM Reply With Quote
Just to state the obvious and ensure tank has (as in this case) been purged - we had a local chap kill himself a few years back trying to make a bbq from an oil drum/gas cylnder that exploded when he cut into it.
