Author: Subject: Black Top Code Reader
the_big_1
posted on 6/11/20 at 09:29 PM Reply With Quote
Hi guys,
What low cost systems have you used etc that reads fault codes on a Blacktop and also shows live dat, engine speed, coolant temp etc.
Bluetooth too if possible but not a must have.
Cheers!
gremlin1234
posted on 6/11/20 at 11:53 PM Reply With Quote
torque is a very good start (android)
also forscan
the_big_1
posted on 6/11/20 at 11:57 PM Reply With Quote
Hi ya,
I am on android, Samsung, have you a good link I can use?
gremlin1234
posted on 7/11/20 at 12:17 AM Reply With Quote
Originally posted by the_big_1
Hi ya,
https://play.google.com/store/apps/details?id=org.prowl.torquefree&hl=en_GB
edit: lite is free and I think it does all you want
[Edited on 7/11/20 by gremlin1234]
the_big_1
posted on 7/11/20 at 12:21 AM Reply With Quote
Hi ya,
Perfect, what hardware works with the app?
Cheers.
gremlin1234
posted on 7/11/20 at 12:34 AM Reply With Quote
Hi ya,
Cheers.
seems to work well with my amazon cheepy bluetooth
Vgate scan - obd scan
to samsung phone
the_big_1
posted on 7/11/20 at 12:36 AM Reply With Quote
Hi ya,
Do you have a link to it, sounds a good app, just need the hardwear
gremlin1234
posted on 7/11/20 at 11:22 AM Reply With Quote
I dont have a link sorry. (it was a christmas present a few years ago.)
but its the penultimate one on this page
https://www.obdinnovations.com/brands/Vgate.html
note, I have only used it on a canbus car
the_big_1
posted on 7/11/20 at 11:32 AM Reply With Quote
Hi ya,
Great stuff. Blacktop is Cambus so should be fine.
Cheers!!!
the_big_1
posted on 9/11/20 at 06:52 PM Reply With Quote
Hi ya,
I bought one but its showing nothing on the car.
https://www.amazon.co.uk/dp/B075R62FTH/ref=cm_sw_r_cp_apa_fabc_s.yQFbP7CC1WE?_encoding=UTF8&psc=1
Car is powered up with a battery charger.
Have 12vdc on ECU
55, 71, 97.
0vdc on
24, 25, 51, 77 & 103.
Continuity from ECU to OBD
Ecu 16 - OBD 2
Ecu 15 - OBD 10
Phones finds adapter, torque app says scanning but nothing.
big_wasa
posted on 9/11/20 at 07:46 PM Reply With Quote
Power and two earths to the obd2 socket ? The car powers the dongle.
the_big_1
posted on 9/11/20 at 07:49 PM Reply With Quote
Hi ya,
Yea have ground on obd 4 & 5.
Power on 16. Dongle lights up when ignition is turned on etc.
obfripper
posted on 9/11/20 at 08:14 PM Reply With Quote
If you have a eec-v ecu from a mondeo/cougar it is not obd compliant even though it uses a standard obd-ii connector, iirc 02-04 focus ecu's are obd compliant and should work with a generic obd code reader.
If the device you have is based on an elm327 chipset, then you can get Forscan working with it on a laptop, it may also be available on android.
The obd compliance doesn't matter with Forscan as the chipset supports the j1850 pwm protocol that the ford ecu's use.
Dave
the_big_1
posted on 9/11/20 at 08:22 PM Reply With Quote
Hi ya,
The device i purchased is BT and mentions "Better than Generic ELM327 ELM 327 V1." How would I get forscan working or is there a better device etc?
Many thanks!!
obfripper
posted on 9/11/20 at 08:29 PM Reply With Quote
Have a look at their website
https://forscan.org/
The basic functionality is free, more complex functions are a licenced addon.
If you post the 4 letter code on the label of your ecu, it may help to id its origin and compatibility.
Dave
the_big_1
posted on 9/11/20 at 08:43 PM Reply With Quote
Hi ya,
The name of the ecu is "LAAN" which seems to come out at a 96 - 200 mondeo?
One device on the forscan is mentioned as "VLINKER" by VGATE. The unit i purchased is VGATE supped too so might work?
big_wasa
posted on 9/11/20 at 09:02 PM Reply With Quote
Firstly test it on a know car. Your tintop, the wife’s, neighbours. Anything.
That will tell you if it’s your dongle or your wiring.
the_big_1
posted on 9/11/20 at 09:06 PM Reply With Quote
Hi ya,
I tried it on my daily car and working fine. Wiring checks out so could be as said, the age of ecu isn't fully OBD compliant. I have ordered another thats linked on the Forscan sight "VLINKER FD"
Forscan said it couldn't see the ecu either but will see what the next dingle does. If not, has to be ECU down which would be mega pants lol
big_wasa
posted on 10/11/20 at 06:17 AM Reply With Quote
I haven't found a Pats ecu I couldn't read with something.
the_big_1
posted on 10/11/20 at 10:18 AM Reply With Quote
Hoping its not knackered as they are rare to find now etc.
The other dongle will be here tomorrow so will find out. I guess a simple check is to fit the pats LED to see if it working correctly.
At least I know if ecu is powring up.
the_big_1
posted on 11/11/20 at 07:00 PM Reply With Quote
Hi ya,
It was the reader, the new one connects so it appears early ones can have an issue.
I have some fault codes and none I expected.
I guess because I haven't run the engine yet, the disconnected MAF and Lambda sensor are not showing errors?
The errors i have the following.
P1000 OBDII Monitor Testing Not Complete. Because engine not run?
P0230 because fuel pump relay is out?
B1600 because not used the PATS key etc?
