Author: Subject: Lights for BEC, stator watt-led.
TMB
posted on 17/12/20 at 10:52 AM Reply With Quote
On Bike engines the stator gives us less watt to play with.
I was thinking LED headlights.
Are there any good LED headlights out there in 4" with high beam/ low beam and a good light pattern.
Must be ECE marked.
peter030371
posted on 17/12/20 at 02:47 PM Reply With Quote
Not seen 4", plenty of 5" or bigger about.
Mr Whippy
posted on 17/12/20 at 03:20 PM Reply With Quote
Do you remember when headlights were large and at night oncoming cars didn't burn out your retinas? I miss those days.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
obfripper
posted on 17/12/20 at 05:09 PM Reply With Quote
I've got a pair of 5.75" jw speaker (iirc model 8630) lamps that are correctly ece marked and uk lh dip, they're in good nick and do side dip and main, but not indicators.
There's not much other choice in 5.75" that is correctly approved, loads more choice in 7" lamps as they fit landies etc.
If they're of any interest pm me.
Dave
Andy W
posted on 17/12/20 at 05:22 PM Reply With Quote
Most bikes run twin headlights anyway, you don't need to fit led
adithorp
posted on 17/12/20 at 06:52 PM Reply With Quote
I've got 5.75" led lamps on mine. They're the ones RussBost was supplying a while ago. Dip, main, DRL and indicator. They had a straight dip cut off and that's fine for me as I do as many miles in Europe as here but a bit of fettling to mount at a slight angle gives an effective left dip.
In use they're great and far better than the previous h4 halogens. Like driving with your own sun. Makes driving at night really good.
If you Google Harley led lamps you'll find loads of them.
http://jpsc.org.uk/forum/
40inches
posted on 17/12/20 at 11:37 PM Reply With Quote
Why not just change the bulbs? https://www.classiccarleds.co.uk/
adithorp
posted on 18/12/20 at 08:52 PM Reply With Quote
Seen a few cars with led headlight bulb replacements fitted and they've all had terrible beam patterns with little or no dip cut-off.
peter030371
posted on 18/12/20 at 10:50 PM Reply With Quote
I fitted led bulbs in Debbie's Mini, great beam pattern, strong light, great (clear) colour
The same bulbs will not fit in my 4" headlights on the Striker
40inches
posted on 19/12/20 at 01:12 AM Reply With Quote
These probably would LED Headlight bulbs
woodsy144
posted on 13/1/21 at 10:30 PM Reply With Quote
https://www.jwspeaker.com/products/bi-led-headlight-model-97/
Can get in right had drive ece compliant. Can get through Summit racing or I am sure local suppliers
