Author: Subject: Kits using FWD donors to give mid/rear layout RWD?
posted on 3/9/21 at 10:31 AM Reply With Quote
Morning all,
What kits (if any) are out there for mid/rear engine cars using transverse engine + gearbox from a FWD donor car to give a RWD result?
Must be car engine + gearbox based, not bike.
Thanks,
Nick
russbost
posted on 3/9/21 at 11:11 AM Reply With Quote
Sylva R1ot was available with car engined option, believe it was the small 1600 Ford engine , Sigma, not certain of donor - Fiesta I think?
Other than that there was a Fury derivative - again, I think, called the Menace, not 100% certain that one was car as well as bike though
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
loggyboy
posted on 3/9/21 at 12:08 PM Reply With Quote
Yes the original Riot. The R1ot got the adapted name to suit the Bike engine.
https://www.riotcars.co.uk/riots-classic/
Mistral Motorsport
loggyboy
posted on 3/9/21 at 12:30 PM Reply With Quote
Its an older one but I also recall seeing one of these a few years back at an autosolo. Didn't appear to like being pushed, all the weight on the rear just meant it under-steered everywhere.
http://www.cc-cyclone.co.uk/
Mistral Motorsport
big_wasa
posted on 3/9/21 at 12:37 PM Reply With Quote
Road Track Race (Mev)Rocket
adithorp
posted on 3/9/21 at 12:45 PM Reply With Quote
Jeremy Phillips has done a few Mid-engined Sylvas. As was his want he usually moved the designs on to other manufacturers after a while.
The Mojo using Ford motors then the Riot developed from that initially with car engine, though later most are BEC and now being done again with ford ecoboost I believe. After that the J15/16/17. J15 has either zetec or duratec. J16 Vectis with MGF (inc subframes) and finally J17 with MGF k-series (but not the subframes). At that point he sold Sylva and retired. The current owner of the mark seems to have mothballed it and I can't remember who has the rights on the earlier models.
...Other than that there was a Fury derivative - again, I think, called the Menace, not 100% certain that one was car as well as bike though
The Menace was bike engine and only 1/2dozen made.
http://jpsc.org.uk/forum/
russbost
posted on 3/9/21 at 01:06 PM Reply With Quote
The Cyclone was an excellent kit, but hasn't been available for ages, I believe there was a dispute & the jigs were cut up!
There was also the Sylva Mojo & further developments of it called Mojo 2 & Mojo SE IIRC
Russell
posted on 3/9/21 at 01:18 PM Reply With Quote
I've got a mid-engined Spire GTR using a VW Passat 1.8T FWD engine and transaxle. It's in-line not transverse but similar in concept to what you're asking about.
Sanzomat
posted on 3/9/21 at 02:12 PM Reply With Quote
Don't forget all of the GTM's from Cox through Heery/Coupe, Rossa 1,2 and K3 and then the Libra/Spyder.
Prior to K3 Rossa they were all mini engined with a mini front subframe at the back. K3 onwards Rover K series and the very later Libra/Spyder had an option to use Honda (and even a couple of Toyota ones for the export market).
Rover K series has been used in many mid engined cars including of course the Lotus Elise S1 and S2 and various kits such as the Marlin 5Exi
There is also the Sonic7 that uses Mk1 Focus engine/gearbox mounted mid/rear. That project has just been sold on but still using the Equilibrium name. Was originally another MEV design.
On the GTM theme, Hambly sportcars are (kind of) still marketing a new incarnation of the orginal GTM coupe that uses Fiesta Zetec engine/box mid mounted.
The Raffo Belva used Ford Zetec amidships too.
Myke 2463
posted on 3/9/21 at 03:52 PM Reply With Quote
Midlana
If you like a challenge check out the Midlana.
Be Lucky Mike.
posted on 3/9/21 at 05:49 PM Reply With Quote
Thank you, some to check out.
I have a Peugeot Mi16 engine and gearbox in mind (as I have them available to use). Happy to modify something to use what I have though.
russbost
posted on 3/9/21 at 07:18 PM Reply With Quote
I'm sure you could drop that in the back of a Furore, perhaps with some minor mods!
posted on 4/9/21 at 12:14 PM Reply With Quote
You may have a good point
ianhurley20
posted on 4/9/21 at 09:37 PM Reply With Quote
My money would be on the Midlana as well CorseChris on here has done a brilliant build - documented on here https://forum.wscc.co.uk/forum/topic/127535-non-westfield-build/
Ok bit of a challenge but it gives you lots of freedom to decide on spec and build and keeps the old 7 very much in mind
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why! - 03/21 - Now finished
jacko
posted on 5/9/21 at 02:38 PM Reply With Quote
Not a kit but I always liked the lotus europa
posted on 6/9/21 at 07:42 AM Reply With Quote
Always thought that VAG transmission would lend itself to that sort of application. Seemed a shame in their tin tops as it pushed the engine so far forward over the front axle, but for better suited for the application you describe (and I'm after).
Schrodinger
posted on 6/9/21 at 09:03 AM Reply With Quote
IIRC you could buy the Europa as a kit when it first came out to negate purchase tax.
Keith
Mike Wood
posted on 11/9/21 at 08:27 PM Reply With Quote
What about a T89 Razorbill built from plans with a replica Lola sports racer body and VAG 1.8 turbo engine and gearbox: http://www.t89.co.uk/product/razorbill-full-plans-pack/
Mike
