Author: Subject: Garage shelving
Mike Wood
posted on 25/11/21 at 01:15 PM Reply With Quote
Garage shelving
Hi
Anyone got any recommendations please for reasonable quality good value freestanding garage shelving?
Mike
posted on 25/11/21 at 01:56 PM Reply With Quote
Got some stuff like this that does me good
https://www.toolstation.com/eco-shelving-bay-with-chipboard-she lves-5-tier/p71743
Just slots together - no bolts.
Quinten
posted on 25/11/21 at 02:41 PM Reply With Quote
I've got 4 of these https://www.screwfix.com/p/5-tier-steel-heavy-duty-shelving-900-x-450-x-1800mm/165pv when they were £50 per 2.
HowardB
posted on 25/11/21 at 04:23 PM Reply With Quote
old dexion - occasionally on gumtree or ebay
or the new equiv from BigDUG
I like old dexion, very solid, a friend has a workbench and rack combo from BigDUG - solid too - just more costly
HTH
Howard
hellbent345
posted on 25/11/21 at 06:46 PM Reply With Quote
+1 for the dexion / big dug HEAVY duty stuff - I’ve bought the cheaper end of stuff before and while it’s OK for the first time you put it together I found it a nightmare to take apart because it’s quite flimsy and doesn’t then go together well the next time..
Also be careful with the shelf material, the thinner stuff warps under weight during the winter when they get a bit soggy. Ended up replacing all my cheap shelf material with 12mm osb which was better for stability in damp conditions and then replaced the lot with the dexion system with I think either 18 or 22mm chipboard shelves which has been great for four workshop moves
adithorp
posted on 26/11/21 at 08:40 AM Reply With Quote
I got some from BigDug during lockdown. I didn't need heavy gauge but didn't go for the lightest either (don't recall which exactly). It was pretty solid once assembled despite the components feeling a bit flimsy. Not convinced it'd be as solid if taken apart and rebuilt but it was a lot less faff than dexion with nuts and bolts.
[Edited on 26/11/21 by adithorp]
http://jpsc.org.uk/forum/
Mr Whippy
posted on 26/11/21 at 09:21 AM Reply With Quote
all I'll say is make sure you also fix it to the wall
posted on 26/11/21 at 10:41 AM Reply With Quote
Ditto - fix the top rear uprights to the wall to stop it tipping and place heavy stuff on the lower shelves.
designer
posted on 29/11/21 at 12:07 AM Reply With Quote
I have one of these for sale. £30
contaminated
posted on 29/11/21 at 12:55 PM Reply With Quote
Big dug all day long for me. I have these:
https://www.bigdug.co.uk/mega-deals-c411/bigdug-essentials-4x-shelving-bays-workbench-kit-p1401
and this:
https://www.bigdug.co.uk/workshop-workbenches-c348/workbenches-c11604/garage-workbenches-c11610/bigdug-essentials-garage-workstation-mega-deal-p19952< br />
Very pleased.
Tiger Super Six Independent
www.southernkitcars.com
posted on 30/11/21 at 08:27 AM Reply With Quote
That looks pretty good to me. A workbench with storage drawers all-in-one.
I made myself a workbench using some old 4x2 timber I had and a cheap bit of kitchen worktop from Wickes. Sturdy enough and space underneath, but no drawers to keep stuff tidy in.
https://www.locostbuilders.co.uk/photos.php?action=g al&user=nick205&folder=Workbench
contaminated
posted on 30/11/21 at 11:36 AM Reply With Quote
Nice. I spent a bit of time working out what would fit. I probably spent the best part of £1500 including the tool chests, but I wanted the new garage to get off to a good start. I can't tell you what a difference it makes having so much storage and knowing where everything is.
posted on 30/11/21 at 03:54 PM Reply With Quote
Spot on - having things stored well just makes them so much easier/faster to find and put back (keep tidy).
That said, I lost my garage (integral to the house) as we converted it to a bedroom for one of the kids (cheaper than moving house). The issue I have now is a bicycle mad son with several bikes + my bikes + other family bikes. Storing bikes is hard work - making sure everyone's got good access to them.
G13BLocost
posted on 1/12/21 at 10:20 PM Reply With Quote
+1 for BigDug
Bluemoon
posted on 3/12/21 at 02:11 PM Reply With Quote
+1 bigdug - just choose a model based on your needs (ie. shelf strength and metal thickness). Have two set's cheap ish versions o.k. but don't like being moved heaver duty would be better if you can afford it or build some from 2x4...
