Author: Subject: Cheap digi dash
whpracer
posted on 30/3/05 at 11:05 AM Reply With Quote
Cheap digi dash
found some cheap digi dash on the net,
looks cool
price is 159 euro = +/- 100 pounds
http://www.marktplaats.nl/index.php3?g=motoren&u=ducati&ID=8663
[Edited on 30/3/05 by whpracer] Rescued attachment j,.jpg
whpracer
posted on 30/3/05 at 11:06 AM Reply With Quote
whpracer
posted on 30/3/05 at 11:07 AM Reply With Quote
Kitlooney1000
posted on 30/3/05 at 11:28 AM Reply With Quote
Very nice, wonder if they do it in mph also
Doesnt matter what Sh*t life throws at you, there is always some other poor bugger worse off!!!!!
mangogrooveworkshop
posted on 30/3/05 at 11:34 AM Reply With Quote
- Motoren/scooters/brommers/accessoires / Ducati
Offered: Very beautiful DIGITAL DASHBORD geschik for every type of engine
Price: € 159.00
Description: This is universal digital dashbord for every type engine.
Arranged for:
2 takt
4 takt
itself construction
honda
ducati
aprilia
kawasaki
suzuki
etc.
The functions:
- go for a ride digital meter
- go for a ride maximum (also can see you at which speed that was)
- digital km meter
- sniffing meter (km)
- maximum speed (also to see at how much going for a ride that was
- Digital petrol meter
- coolant temperature
- outside temperature
- total km score
Dimensions: 77mm high
36mm broad
120mm length
Vast guide for placing the dashbord.
This dashbord are very simply assemble (+ - 3 hours)
Apparte stekker are supplied as from the dashbord.
price: 159 euro
If you have questions if this dashbord want order can you our bels or mail to address mentioned below.
delivery period: 2 days
We send by the complete country, also under rembours.
125cc World
hovenierstraat 104
2671 DB needle district
0174-614991
06-42171241
www.125cc.nl
info@125cc.nl
Trefwoorden: 125.250.600.750.900.1000.1100.1300 r rs125 rs250 rsv rsvr rs50 50,125 zxr gsxr cbr
Internet site: http://www.125cc.nl
Photograph: Click here to examine the photograph
Date: 08-03-2005, 16.02
Given: 369 examined time.
Advertiser
Name: 125cc World (e-mail the advertiser) (all advertisements)
Phone number: 0174-614991
Place of residence: needle district
Region: Zuid-Holland
DarrenW
posted on 30/3/05 at 01:13 PM Reply With Quote
Its a shame it doesnt do rpm (unless it does but description lost in translation).
Need to know that it is programmable for calibration, available in mph, mph range is high enough, how the speed pick upo works and what sort of sensors used for temp and fuel level.
Outside temp is a good idea.
I still favour this one - http://www.banditmania.co.uk/Site_Map.htm
this is better link - http://www.banditmania.co.uk/digital_clocks.htm
[Edited on 30/3/05 by DarrenW]
MikeR
posted on 30/3/05 at 02:31 PM Reply With Quote
look up the quad master range http://www.quad-master.co.uk/accessories_quad_atv.html
whpracer
posted on 30/3/05 at 03:54 PM Reply With Quote
The translation according mangogrooveworkshop is not correct
I'll try to make it complete
the dash futures:
Rpm readout
Max rpm at given speed
Speed readout
trip counter
max speed ( incl. rpm at that time )
fuel gauge
coolant temp
outside temp
total trip counter
It comes with all needed sensors and a wiring loom
so instalations should take up to 3 hours max
Mave
posted on 30/3/05 at 04:57 PM Reply With Quote
I'll drop them an email with questions, and let you know. My dutch is probably better than most of yours.
Marcel
RazMan
posted on 30/3/05 at 08:59 PM Reply With Quote
Sniffing Meter??
Raz
Lozec
posted on 13/4/05 at 02:34 PM Reply With Quote
Marcel
Hello Martcel,
Have you received any answer yet? I'm interested as well!
BR //Bernt, Sweden
Mave
posted on 13/4/05 at 03:13 PM Reply With Quote
Oops, sorry. I forgot, I did get a reaction:
- speed range is unlimited (!?!?!)
- only km/h, no mph
- speedsensor gets signal from three magnets
- for tacho: a wire is wrapped around the coil cable, and thus gives a signal
- fuel level; can be attached to any sender
- temperature; standard sensor can be used.
- there is a battery inside for storage, but the rest is connected to the car's 12V circuit
- lighting is always on (when in use).
I hope that helps (I did find cheaper places though!)
Marcel
Lozec
posted on 14/4/05 at 10:32 AM Reply With Quote
Marcel
And the cheaper place is??
Mave
posted on 14/4/05 at 03:05 PM Reply With Quote
http://www.racing-parts.nl/catalog/product_info.php?cPath=37&products_id=380
or even cheaper:
http://www.kc-engineering.de/k008u003s001.htm
Lozec
posted on 15/4/05 at 05:57 AM Reply With Quote
or even cheaper:
GREAT, thanks for quick info!!
/Lozec
posted on 15/4/05 at 09:22 AM Reply With Quote
Where does the speedo read from? you could multiply the calibration by a conversion factor to read in MPH but it will still say KM/H after the readout. I don't think that would matter.
akumabito
posted on 16/4/05 at 09:41 AM Reply With Quote
But how about the tacho? Wouldn't it mess up because it's meant for a 1 cilinder engine? (just a little scooter)
A sportsbke tacho should work, most of those bikes have 4 cilinder engines..
