Author: Subject: Dash
shortie
posted on 6/5/05 at 07:41 AM Reply With Quote
Dash
Managed to get the dash covered last night, turned out not bad in the end, hopefully should get it fitted with DigidashBright 6 tonight
Dash covered
Dash covered
Rich.
turbolag
posted on 6/5/05 at 12:59 PM Reply With Quote
Looks tidy mate.
If it ain't broke, you ain't fiddlin' hard enough!
posted on 6/5/05 at 01:11 PM Reply With Quote
That's a very similar shape to mine. I found that the bit that extends down from the middle will tend to move around, especially when operating switches etc. - I ended up taking a little bit of angle aluminium and fixing the bottom to the tunnel cover, using a couple of the cover's fixing screws.
shortie
posted on 6/5/05 at 06:48 PM Reply With Quote
Thanks guys,
I think you are right David, exactly what I was going to do to keep it all nice and secure
Rich.
ned
posted on 6/5/05 at 10:14 PM Reply With Quote
looks like a good start rich, how are you mounting/facing the bright six? would be interested in seeing some piccies when you're done
Ned.
beware, I've got yellow skin
shortie
posted on 7/5/05 at 07:03 AM Reply With Quote
There's a hole already there for the bright 6, I am going to mount it in carbon and then put this behind the dash so it is recessed.
Will post some pics when I'm done.
Rich.
