New Topic New Reply
Author: Subject: how about my new upright's ????
whpracer
posted on 16/10/05 at 07:57 PM Reply With Quote
after looking at different rear hub's I decided to go on an alternative way.
I turned the original sierra hub carrier down to a nice round shape and made a nice hub from 14mm cds tube.
so check my website for further details
please give your comments
[Edited on 16/10/05 by whpracer]
[Edited on 16/10/05 by whpracer] Rescued attachment DSCF0156.JPG
mark chandler
posted on 16/10/05 at 08:17 PM Reply With Quote
I like it.
In the stage of planning mine, you,ve made up my mind.
Mix
posted on 17/10/05 at 06:09 AM Reply With Quote
Nice lightweight upright but how do you plan to attach the calliper?
Mick
kb58
posted on 17/10/05 at 01:36 PM Reply With Quote
Are you planning to box in the framework? My only concern is it may not be rigid in torsion (twisting) which will come from braking and acceleration.
Also, have you tried pressing in the bearings yet? Unless a sized plug was used during welding, a bearing housing can and will change shape and size...
[Edited on 10/17/05 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
cymtriks
posted on 17/10/05 at 07:39 PM Reply With Quote
KB58 is right on both acounts.
If you get any resistance to fitting the bearings then this is what has happened. The tubes are triangulated in the cars side to side direction but not in the cars fore-aft direction so they will be very weak in acceleration and braking.
erwe
posted on 18/10/05 at 04:51 AM Reply With Quote
I did about the same. No problem to push the bearings in. The housing is thick so there was a little distorsion. I mounted the calipers on the diff.
New Topic New Reply
