Author: Subject: VDO electronic speedometer + sender
lightspear27
posted on 3/11/05 at 11:20 AM Reply With Quote
I have a new VDO electronic speedometer for my Ginetta ...
BUT
... no wires, instructions, diagrams, sender !!!!
So I'm looking for a sender. I understand I have to use a "hall effect sender", better is a "plug-in hall effect sender" ... am I right?
Where can I find the sender I need + fitting instructions, wires, wiring diagrams, calibration instructions?
I imagine it is important to say I have a Type 9 gearbox?!
Is there someone who can supply me with a part number?
Any information will be helpfull.
Thanks.
Myke 2463
posted on 3/11/05 at 03:09 PM Reply With Quote
Try www.lotension.com. they sell VDO instruments at low prices. Be Lucky.
Myke 2463
posted on 3/11/05 at 03:11 PM Reply With Quote
Lowtension has a W. sorry
piddy
posted on 3/11/05 at 03:17 PM Reply With Quote
I dont thnk you will get much response from Lowtension they seem to have gone broke.
lightspear27
posted on 4/11/05 at 09:41 AM Reply With Quote
Thank you,
tried Lowtension but no answer.
Now trying www.greengauges.com and www.speedycables.co.uk
Regards
DarrenW
posted on 4/11/05 at 10:54 AM Reply With Quote
Try ETB as well. I recall that they had a special offer on VDO gauges recently so may know a thing or 2 about sender comatibility.
lightspear27
posted on 4/11/05 at 12:02 PM Reply With Quote
... will try
thank you
bob
posted on 4/11/05 at 07:04 PM Reply With Quote
VDO senders
http://www.merlinmotorsport.co.uk
lightspear27
posted on 7/11/05 at 07:26 AM Reply With Quote
Thank you Bob, Darren, Piddy, Myke
... I've sent e-mails to all the mentioned companies explaining my needs ...
I'm now wainting for the answers and will keep the forum informed of the answers.
matty_64
posted on 7/11/05 at 09:46 PM Reply With Quote
granada v6 type 9 has a speed sensor on the tailcasing.atb say i should be able to use this.you may be able to do similar.hall sensors & daisy wheels can be a pain to set up.give atb a call i found them very helpful
soperfast
posted on 11/11/05 at 08:03 AM Reply With Quote
On the outer casing should be printed a number; this is the Speedo number.
Usually 9 digits long. From this information I should be able to obtain the correct sender and wiring information.
If no number - what diameter, max speed and how many pins? (should be 8).
Neil.
Syd Bridge
posted on 11/11/05 at 08:56 AM Reply With Quote
Let me know your email, and I can send full calibration instructions on pdf.
Google for Siemens VDO, you should find thje full instructions on the USA site.
[Edited on 11/11/05 by Syd Bridge]
soperfast
posted on 11/11/05 at 09:08 PM Reply With Quote
lightspear27
posted on 15/11/05 at 08:22 AM Reply With Quote
Hi all,
Thank you for all these informations. (Syd Bridge you have U2U)
Soperfast, thank you for the diagram. I will U2U the 9 digit code on the Speedo as soon as possible (this evening I hope).
I'm not able to have a look at the gearbox right now but it came from a Ford Sierra 2.3D (I do not remember which year) but I think it only has a "hole" for the mechanical cable.
I received two answers from the companies you told me to ask for informations. One from speedycables and one from merlin motorsport.
Speedy Cables say they can supply a short speedo cable with a sensor on the end that will work my speedo. Total cost : 66.15£ (sent to Belgium).
Merlin Motorsport also say they can help. I'm waiting for more informations from them.
lightspear27
posted on 15/11/05 at 09:01 PM Reply With Quote
Thank you for the info syd ... seem really complete
... and in french ... PERFECT (yes, I live in Belgium)
lightspear27
posted on 17/11/05 at 07:51 AM Reply With Quote
soperfast ... you have u2u
