<<  4    5    6    7    8    9    10  >>
Author: Subject: Bodywork for CANAMSA
Fred W B
posted on 16/4/08 at 04:52 PM Reply With Quote
I left out my "trick" , which was to put the longitudinal stringers 200 mm, far enough apart to fit in the pistol grip driver.
I put the connector blocks (with the two screws) on the transverse stations first, as I build up the framework longitudinally, then when the stringers went in I just had to put the third screw into the stringers
I am sure the right angle drill will work too, though just mayby a bit difficult to "muscle" . I stopped counting once I went past 1000 blocks x 3 screws each!
Fred W B
[Edited on 16/4/08 by Fred W B]
ghetto_eddie
posted on 17/4/08 at 08:00 AM Reply With Quote
Fred,
I developed a similar method to what you mentioned, assembling the blocks on the "stiffeners" first, and now just to assemble... but unfortunately my sections are 175mm apart! shot myself in the foot there!
ime currently on 400 blocks pre-assembled onto my stiffeners! FUN
I bought my right angle drill adapter last night... shoddy piece of Cr*p but it may just work!
Sorry for clogging up your thread!
Edd
Fred W B
posted on 25/5/08 at 05:51 PM Reply With Quote
It's been a while, but I have very busy climbing up the learning curve of laying up and working off fiberglass. Having now consumed the majority of a 25 kg drum of resin, I have about 80 percent of the pattern covered in a generous layer of resin and CSM.
As I was warned, this is messy, tedious and unpleasant work that definitely requires a "knack" to be acquired. It is the most difficult task psychologically so far on my project. I am definitely very glad I spent as much time as I did getting the shape to my satisfaction before I started with the resin.
I attach some detail photos. As always the edges and returns take a lot of time. As you can see the pattern looks a lot worse for a while, before it starts to look better again. At the moment I am grinding back obvious high spots and overlap joints with a flexback wheel in an angle grinder, and reworking occasional "soft" spots in the surface, where I caught an airbubble in the layup. I'm looking forward to getting this stage finished so I can get onto the final smoothing of the surface with a long board etc etc etc
Fred W B
skin 1
skin 1
Fred W B
posted on 25/5/08 at 05:53 PM Reply With Quote
skin 2
skin 2
The surface of the return is not complete yet in this shot
[Edited on 25/5/08 by Fred W B]
Fred W B
posted on 25/5/08 at 05:54 PM Reply With Quote
skin 3
skin 3
Fred W B
posted on 25/5/08 at 05:57 PM Reply With Quote
skin 4
skin 4
Ivan
posted on 26/5/08 at 12:58 PM Reply With Quote
Always interested to see your progress Fred
Fred W B
posted on 8/6/08 at 07:57 PM Reply With Quote
For the last three weekends, and also some weekday evenings, I have pretty much done nothing else than graft in the garage, in order to get the damn fiberglass skin finished. Now every square centimeter (except under the nose) is covered, some of it worked off fair, and I have actually started applying some filler - Yay.
I couldn't resist working off the first section of filler I applied and I'm very happy with the way the surface came up. This is after just one application of filler.
Fred W B
[img][/img]
Fred W B
posted on 8/6/08 at 08:04 PM Reply With Quote
In this shot the camera maybe makes it look like the lower line of the side pod/door is bowing inwards a bit in the centre, but checking with a straight edge it is dead flat in the longitudinal direction, except for where you see the guide coat.
Fred W B
filler 2
filler 2
[Edited on 8/6/08 by Fred W B]
posted on 9/6/08 at 07:26 AM Reply With Quote
excellent.
has it been asked before - but with all that sanding going on, how do you manage to keep the garage so tidy?
Fred W B
posted on 9/6/08 at 08:07 AM Reply With Quote
Thanks 02. I keep an airline handy and blow the dust away periodically. It piles up on the floor against the walls like snow
And of course it goes everywhere. Across the yard, on the cars, on the dogs etc etc. I'm surprised the neighbours haven't complained.
Fred W B
[Edited on 9/6/08 by Fred W B]
violentblue
posted on 15/7/08 at 04:44 AM Reply With Quote
so whats the status?
looking forward to seeing it in one color
(primer?)
a few pics of my other projects
Fred W B
posted on 15/7/08 at 06:11 AM Reply With Quote
HI Blue
Have now got a layer of filler worked off over almost the entire pattern. Not much to see though, just how many pictures of sanded filler can you all stand?
I haven't been able to devote much time to the project over the last few weeks, but I hope to get the first layer of surfacer primer on in a month or two.
Fred W B
[Edited on 15/7/08 by Fred W B]
Delinquent
posted on 16/7/08 at 11:14 AM Reply With Quote
Probably more than you'd imagine
mistergrumpy
posted on 17/7/08 at 10:43 PM Reply With Quote
Wow! Don't know how I missed this thread previously. Been thinking about it today whilst trudging around at work. Am I right in thinking that after all those measurements that you took you knocked a few mm off them overall to take into account the depth of the filler etc.?
Great project
Fred W B
posted on 18/7/08 at 05:37 AM Reply With Quote
thanks Grumpy
That would have been the right thing to do, but we didn't bother. Who knows how close we actually are to the real thing anyway?
Fred W B
Fred W B
posted on 20/7/08 at 04:21 PM Reply With Quote
A couple more photos. Have now worked off the second go round with filler on the rear clip top surface and the whole left hand side.
[img][/img]
Fred W B
posted on 20/7/08 at 04:28 PM Reply With Quote
Although it doesn't look like it here, due to the camera angle, I made a template so I could match the top curve of the LH and RH side rear arches.
Fred W B
[img][/img]
:{THC}:YosamiteSam
posted on 20/7/08 at 08:04 PM Reply With Quote
dont you just love seeing someone building a car like this? to put so much heart and soul into their *baby* and seeing it starting to look like a car too.
i think there are 2 types of kit car builders - those who make bits for the car and those that buy bits - personally i prefer the making bits type - because it stimulates the mind the make better things- after all if you can make something like this - you could make just about anything given the time and patience
Fred W B
posted on 6/8/08 at 11:20 AM Reply With Quote
Random Thoughts while shaping
I haven’t posted much progress detail lately. The work I’m doing now doesn’t show well in photos, but the shape and surface is getting better and better. I prefer to post details of what I’ve done, not talk too much about what I’m still going to do. I saw on another car building forum a guy posted nice renderings of a car body he was going to build. He gave himself a month to build the plug. After two weeks he had a lump of hacked about foam, and he gave up. Sorry mate – It doesn’t work like that.
All this sanding means you have a lot of time to think while toiling away in the garage. Making a body pattern single handed is a silly amount of work. To do this I think you do have to be determined, some would say bloody minded. It reminds me of when I was cycling competitively, and later racing karts. Sometimes while doing the activity (cycling – while feeling bad and just just hanging on the back of a bunch, karting – being nerfed off the track, or having other issues during a race day) I would think to myself – “this is madness, I’m not enjoying myself, I’m going to give up”. But then at the end of the day you see you have finished a bit higher up than last time, and you feel better, and so you give it yet another go. Having like minded mates to chat/drink beer with after also helps a lot.
I have seen a couple of references that state doing a body pattern the old fashioned way takes maybe 1000 Hours. I reckon I am averaging at most about 10 hours a week on the project, so that would be two years. Currently just starting the 20th month of work on the pattern and I hope to finish this year still, so that 1000 hours seems about right in my case. I read in USA magazine “Hot Rod”'s paint and body issue that rod or muscle car high end professional paint jobs may have 200 to 300 hours of block sanding alone in them – and that’s on an existing car!
I try to concentrate on just the area I am working on, without thinking about the all the work yet to do. When I get despondent I look back through this thread and see how far I’ve come, and that improves my resolve to keep going, as does the positive responses from you guys here.
Experienced builders might smile at the notes below, but I put this down for others who may be considering a similar project. Maybe they are just notes to myself:
There is no “easy way”
Don’t agonize over how to approach or do something. Just start, and move on from there. You may find that eventually the first thing you did has been changed/replaced, but at least you started.
Get each stage as good as you can before you move onto the next. It’s easy to shape wood/foam, less easy to shape GRP, a pain to correct stuff at the body filler stage. Getting it absolutely correct at the drawing stage would be first prize.
Don’t expect to get every section 100 percent the first time. Get it good, do another section, work round the car, when you get back to it you can get it better.
Even when you don’t feel like it, or just have a little bit of time, get in the garage. Things don’t get built if you aren’t in the garage. Even if you just tidy up a bit, you will do something.
Do everything to the standard you want. If it bothers you every time you look at something, rework it.
If you get tired, or find yourself rushing to finish something at the end of a day, stop. Do it next time. You will make mistakes and have to redo it if you don’t.
When you think you are just about finished, you aren’t - The last 10 percent takes 90 percent of the time.
Anything can be fixed / reworked.
Fred W B
adithorp
posted on 6/8/08 at 12:41 PM Reply With Quote
"...(cycling &#8211; while feeling bad and just just hanging on the back of a bunch,..."
I know that feeling! It's looking good.
adrian
http://jpsc.org.uk/forum/
Benonymous
posted on 6/8/08 at 01:05 PM Reply With Quote
Impressed
Hi Fred, I'm not only impressed with what you have achieved but also with your work philosophy. The car you are building comes from an era where design was functional but also aesthetically pleasing. Your ideas about carrying out the work also come from that era of patient craftsmanship.
I know for a fact that one day I'll see a gleaming Lola twinkling in the sunlight on this thread. I don't care how long it takes.
Power to your sanding arm mate!
sgraber
posted on 6/8/08 at 02:53 PM Reply With Quote
Thanks for that philosophical musing Fred. You've dredged up a rush of memories on my part! I would like to just stand beside you in agreement on all of your above mentioned points.
That part about just doing a small thing every day even when you don't feel like it, that is a core value that will see you finish this project and it's the one trait lacking in so many people. Dedication. You've got it in spades! Congratulations.
G.
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
Fred W B
posted on 22/12/08 at 05:42 PM Reply With Quote
So, an update!
I have not been making progress as fast as I'd like, getting a consistent uniform shape and radius on the edges around all the openings has been taking ages. I have got through over 50 kg of body filler so far. I am now working with 120 grit paper and trying to get up to a dark ABF guide coat that will be the last iteration before the primer surfacer can go on.
Currently I am pretty happy with all the top, side and rear panel surfaces, as well as the cockpit edges. The rear wheel arch edges are pretty much done, as are the edges of the "hip" ducts. The internal surfaces of these still need some more work, as does the front wheel arches and the edges of the openings in the front of the nose. After that the only major job left is finishing the inner faces and edges of the radiator exit duct.
I attach some photos
Fred W B
buck dec 018
buck dec 018
[Edited on 22/12/08 by Fred W B]
Fred W B
posted on 22/12/08 at 05:43 PM Reply With Quote
[img][/img]
