Author: Subject: Sierra handbrake cover..
Jumpy Guy
posted on 19/4/06 at 09:20 PM Reply With Quote
my handbrake cover is the rigid plastic standard one. I bought a new leather gaiter for it-
how do i get the standard handle and plastic guard off?
it doesnt seem to have any fixings....
fesycresy
posted on 19/4/06 at 09:22 PM Reply With Quote
Pull and twist, put some effort into it
RazMan
posted on 19/4/06 at 09:24 PM Reply With Quote
I took a pipe wrench to mine - that shifted it
Raz
Jumpy Guy
posted on 19/4/06 at 09:38 PM Reply With Quote
pull and twist what? the handle?
how do i get the plastic guard offt the lever?
RazMan
posted on 19/4/06 at 09:46 PM Reply With Quote
Just to clarify - Are you removing the plastic sheath & button to fit an aftermarket one like this? [shield your eyes] Rescued attachment handbrake.jpg
Raz
wilkingj
pull and twist the plastic hand grip bit on the handbrake lever / handle.
Its just a tight fit.
Best Regards
Geoff
http://www.v8viento.co.uk
indykid
posted on 19/4/06 at 09:49 PM Reply With Quote
i clamped the lever in the vice, then used the open end of a biggish spanner and hammer to belt it off.
just a different approach, but yes, it's just a tight fit.
tom
Jumpy Guy
posted on 19/4/06 at 09:50 PM Reply With Quote
bling!!!
yeah, ive got the standard handle bit, which i need to remove
But
the rest of the lever is covered in a big plastic shroud, which im assuming i need to remove to fir my new leather gaiter?
RazMan
posted on 19/4/06 at 09:57 PM Reply With Quote
[bodge mode] If you are really sure you don't want to refit the old cover, hacksaw down one side to loosen it and just wrench it off with a pair of pliers.
Raz
tom windmill
posted on 19/4/06 at 10:12 PM Reply With Quote
Its very tight, just pull and be careful
indykid
posted on 19/4/06 at 11:32 PM Reply With Quote
istr mine hinged on a plastic rivet, although that may have been one of the other handbrake levers i tried before settling on the p6 one.
either way, a big screwdriver, and a saw of some sort will shift it.
tom
stevebubs
posted on 20/4/06 at 12:32 AM Reply With Quote
Topic Highjack
Is it possible to do similar to a Mk II escort handbrake handle?
Bluemoon
posted on 20/4/06 at 08:58 AM Reply With Quote
I have the same problem. I would like to know if I remove the pastic rivet and cover, will this effect the mechanics of the lever?? (I will keep the handle an button)..
Dan
Ian Pearson
posted on 20/4/06 at 09:46 AM Reply With Quote
Where did you get the gaiter from?
Jumpy Guy
posted on 20/4/06 at 11:38 AM Reply With Quote
got it at detilng, cant remember who from....
main question is - if i hack the plastic cover off, will it affect the operation/action...
