Author: Subject: Rear top wishbone, rear support bolt / nut
JoaoCaldeira
posted on 14/5/06 at 08:16 AM Reply With Quote
I had to cut a bit of the nut (nyloc one) in order to fit the bolt.
Is this normal?
Joao
[Edited on 06/5/14 by JoaoCaldeira] Rescued attachment rear_top_wishbone_bolt.jpg
Avoneer
posted on 14/5/06 at 08:44 AM Reply With Quote
I've had to shorten bolts all the time.
Is your diff on upside down?
Pat...
JoaoCaldeira
posted on 14/5/06 at 03:15 PM Reply With Quote
Sorry.. not bolt... NUT (being portuguese doesn't help a lot when writing...
Joao
Krismc
posted on 14/5/06 at 04:57 PM Reply With Quote
If you shorten a nyloc. it will damage the integretary?? wont it??, therefore fail SVA!!
I was going to grind mine down but, havent as yet!
I need a slimline one, as i cant fit mine either!!
[Edited on 14/5/06 by Krismc]
posted on 14/5/06 at 05:06 PM Reply With Quote
You can narrow them down by holding them against a linishing belt or similar without any problem, don't take any off the lock side though and be careful to keep them flat.
amalyos
posted on 14/5/06 at 06:50 PM Reply With Quote
I used a half nut and locktighted it.
Steve.
smart51
posted on 14/5/06 at 06:56 PM Reply With Quote
Marc sent me two "crushed" nuts for use here. They are full nuts that have been squezed so that the grip the nut. They perform the function of a nyloc but are not as tall.
JoaoCaldeira
posted on 14/5/06 at 06:58 PM Reply With Quote
I didn't cut the nyloc, just 2mm of metal above the nyloc... but I'll get another one an grind the other side...
Thanks,
Joao
Avoneer
posted on 14/5/06 at 07:14 PM Reply With Quote
And the diff???
Pat...
G.Man
posted on 14/5/06 at 08:04 PM Reply With Quote
Originally posted by Avoneer
And the diff???
Pat...
Avoneer, can I ask you how the hell you think he mounted it, if it is upside down?
The lugs wont even come close to fitting if it is not the correct way up..
Opinions are like backsides..
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
Building: MNR Vortx r1(sva pass 07 plate yumyum)
posted on 14/5/06 at 08:58 PM Reply With Quote
Hi guys
The nuts you require are called k-nuts picked mine up from mnr when encountered same problem also available from merlin motosport
posted on 14/5/06 at 10:15 PM Reply With Quote
also available from merlin motosport. Joao lives in Portugal though so not very handy for either of them.
Avoneer
posted on 14/5/06 at 10:33 PM Reply With Quote
Yep, I know that Mr G Man, but in the top pic, the little metal plate oval ring retainer thing is on the bottom and IIRC, they are all on the top of normal Sierra diffs.
Pat...
Avoneer
posted on 14/5/06 at 10:38 PM Reply With Quote
Look at mine here:
http://www.mytigeravon.co.uk/html/differential_2.html
Pat...
G.Man
posted on 15/5/06 at 03:46 AM Reply With Quote
That may be true, but you can see the top bolt in the pic just behind the fuel pipe, and if it was upside down, then the bottom bolt would clearly be in view..
Additionally the bottom casting lug can be seen and the vane direction is correct...
Therefore it is safe to conclude that this diff has a differerent retainer position..
JoaoCaldeira
posted on 15/5/06 at 07:06 AM Reply With Quote
Hi Pat.
Thanks for your concern. The diff is positioned right. But in fact the retainer is not in the same position.
Joao
Avoneer
posted on 15/5/06 at 11:05 AM Reply With Quote
No probs,
Obviously differnet retaining mouting points.
Just an initial concern from the 1st picture.
Pat...
Avoneer
posted on 15/5/06 at 11:08 AM Reply With Quote
Besides, I think it could of been mounted upside down if just the two rear most mounting points had only been used initially.
Pat...
JoaoCaldeira
posted on 20/5/06 at 08:39 AM Reply With Quote
Hi.
There is another very simple solution.
I've used low profile nyloc nuts which fit perfectly; they are 12mm high instead of the standard 14mm.
Joao
mnr laptop
posted on 21/5/06 at 07:27 AM Reply With Quote
yep spot on was going to send some with the rest of the bits
best regards
marc
JoaoCaldeira
posted on 21/5/06 at 11:40 PM Reply With Quote
Thanks anyway Marc
Joao
(How about that for client support )
