Author: Subject: Wrong disc adaptor plate or callipers?
JoaoCaldeira
posted on 19/5/06 at 10:31 PM Reply With Quote
Hi all.
I got the MNR drum to disc adaptor plates and later I discovered some very nice refurbished
calipers in the midle of all the stuff I bought from MNR (yes.. I paid them
later as it was not supposed to be there )
The center to center of the holes in the
* adaptor plate: 9cm
* caliper: 12cm
Which calipers are these? Sierra?
What does use the 9cm spacing? VW Golf? Pug 205?
Thanks for all your help,
Joao
JoaoCaldeira
posted on 19/5/06 at 10:32 PM Reply With Quote
muzchap
posted on 19/5/06 at 10:33 PM Reply With Quote
They dont look like my Sierra calipers?
Have you got a better picture?
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
James
posted on 19/5/06 at 10:51 PM Reply With Quote
Agreed. Odd looking caliper.
HTH,
James
JoaoCaldeira
posted on 20/5/06 at 06:29 AM Reply With Quote
I agree... very bad angle... it was just to compare the holes in both calipers and plate.
Here a couple more
Joao
[Edited on 06/5/20 by JoaoCaldeira]
Avoneer
posted on 20/5/06 at 07:32 AM Reply With Quote
IIRC, it is a rear Sierra one, but you're missing the small slider bracket like the ones on the fronts.
Pat...
posted on 20/5/06 at 10:05 AM Reply With Quote
Pat...
It is a rear sierra caliper but as Pat says it is missing the slider...
Danozeman
posted on 20/5/06 at 11:07 AM Reply With Quote
As both above. Sierra one with missing slider.
Dan
JoaoCaldeira
posted on 20/5/06 at 01:34 PM Reply With Quote
Thank you all very much
Joao
Mr G
posted on 20/5/06 at 04:45 PM Reply With Quote
As far as I know all recon calipers don't come with the carrier as in your case.
Krismc
posted on 20/5/06 at 05:03 PM Reply With Quote
yea i had this problem when i got my refurbed ones, so marc gave me a set of sliders, ive just been to scrappy and got another set to give to him as a replacement!!
plus you will need the slider pins- i bought from ford at a astonishing £8 each (x4)
mnr laptop
posted on 21/5/06 at 07:26 AM Reply With Quote
hi jaoa we have just had a load of sliders back from the powdercoaters if you want a pair let me know asap then they can come with the uprights etc
best regards
marc
