Author: Subject: IRS uprights
posted on 31/5/06 at 10:55 AM Reply With Quote
IRS uprights
At some stage I have to design and build an IRS for my car. I have searched the site but did not really find the answer to my question. What are the pro's & con's of having the single joint at the bottom and the double joint at the top as opposed to the normal way of the opposite. It would seem to make the mounting of the shock easier as it could be in the centre of the two joints and mounted to the upright.
I can think of a disadvantage but would like to hear some of your views on the subject before I prejudge mine.
Bruce Kelly
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
Bob C
posted on 31/5/06 at 11:21 AM Reply With Quote
if you think of the wheel as a lever - whatever force the contact patch generates( corner/accelerate/ linear brake) there is about 2x the stress on the bottom pivot compared to the top.
so 2 at bottom & 1 at top means same size joints everywhere ;^)
Fred W B
posted on 31/5/06 at 11:33 AM Reply With Quote
I started out like that, with two at the top, but if you try to get the mounting points as far away from each other as possible, within the constraints of the wheel rim, you end up with the lower joint, and therefore wishbone very close to the ground, and keeping the wishbone flat then determines the lowest chassis point, IE no ground clearance under the chassis.
It was also tricky to get the shock to clear the driveshaft and the top wishbone, so I eventually went with the single at the top. You usually find their is a reason everyone does it the same way!
Fred W B
Rear Suspension mock up
[Edited on 31/5/06 by Fred W B]
posted on 1/6/06 at 11:28 AM Reply With Quote
Hi Fred,
Thanks for your reply. I've seen some of your work on a recent post and thought it looked pretty good. Those were the sorts of concerns that I imagined. As I am building a seven the shock can come of the top and is located under the rear frame. I think that i will draw it up and see how it might work as it is similar to the silvia rear suspension on my donor. There is a decent sized ball joint on the bottom (14mm thread) which is exactly the same as the bottom of the front upright. I can reuse this. The actual rear upright is useless as it has really weird geometry.
