Author: Subject: Zetec PCV system
zetec7
posted on 16/6/06 at 05:08 PM Reply With Quote
Zetec PCV system
I'm using a Zetec 2.0 on Weber 45DCOE's on an Ehrlich igniton (haven't started it up yet), but I'm wondering about the large metal PCV cannister below the exhaust. It's normally vacuum controlled (with engine vacuum as the "signal" to release the pressure), but obviously with Webers, there isn't any. I don't want to have internal pressure causing seal leaks or anything.
I'm sure many of you (being an inventive and ingenious lot!) have gotten around this problem. Suggestions? Thanks!
Markp
posted on 16/6/06 at 05:17 PM Reply With Quote
Is this what you mean??
clicky
Mark
big_wasa
posted on 16/6/06 at 05:40 PM Reply With Quote
Yep there is pic of mine there with that bit bined. As you say it does bugger all with out the vacume to open it.
zetec7
posted on 16/6/06 at 05:46 PM Reply With Quote
Pretty much...just want to make sure no-one's had problems with pressure buildup
Markp
posted on 16/6/06 at 05:54 PM Reply With Quote
no problems at all!!
Mark
lsdweb
posted on 17/6/06 at 09:23 AM Reply With Quote
Blank it off - that's the advice from Dunnell's and that's what I did.
