John Bonnett
posted on 4/7/06 at 12:57 PM |
Brake return spring
Can any one please tell me if a return spring is necessary on the brake pedal. I am using a bias twin master cylinder set up.
Thank you for your help.
John
Markp
posted on 4/7/06 at 04:04 PM |
I haven't got one on mine and I've never found it a problem
Mark
nitram38
posted on 4/7/06 at 04:20 PM |
I have floor mounted pedals and I have put a helper spring around the pivot.
It does not affect the feel of the pedal, but it ensures that there is no strain on the master cylinders, so their internal springs should last a bit
longer.
John Bonnett
posted on 4/7/06 at 04:24 PM |
Thank you for that. I'll try without and see how we go. I have a hydraulic brakelight switch so I guess if that goes out when the pedal is
released, there is no internal pressure in the system and all will be okay.
John
