Author: Subject: Type 9 - removing rear oil seal
Just
posted on 22/7/06 at 11:19 AM Reply With Quote
I bought a pre-built Tiger and the previous owner didn't think replacing the input seal was worth it (or they replaced it with a poor one).
Anyway the result is a completed car with a (very small) oil leak from the rear seal.
Is it a real pain to replace the seal now the car is complete or can I unbolt a UJ somewhere and do it fairly easily?
If not how easy is it to get to the filler point and just top the gearbox up from time to time (the leak is that small and only just after it has been out)?
[Edited on 29/7/06 by Just]
Danozeman
posted on 22/7/06 at 11:43 AM Reply With Quote
I take it by input seal you mean the rear seal where the propshaft goes in??
If so u can unbolt the prop from the rear diff and slide it out of the way. Lever the old one out and use a punch to knock the new in. The only cost a couple of quid so well worth doing as its an arse to fill the box if u havent got a pump.
Dan
Johnmor
posted on 22/7/06 at 05:22 PM Reply With Quote
Had to repllace my oil seal just last week, remove prop and prise out the seal, watch and not damage the housing, i would also use sealer around the out side of the seal as this is where my problem came from, not the joint between seal and propshaft but the external of the seal housing.
Took about 1hr , no big deal just awkward.
Just
posted on 23/7/06 at 11:50 AM Reply With Quote
Thanks guys, sounds easy enough then, does oil come out when the prop is out? If so and anyways can I squirt some more in while it is out?
grusks
posted on 23/7/06 at 06:46 PM Reply With Quote
Jack the back up higher than the front, and none should come out.
Need More Money
Just
posted on 29/7/06 at 11:13 AM Reply With Quote
I have been hitting the seal from the outside towards the inside with a hammer and a screwdriver. I can only do this on about a third as the tunnel prevents me from doing it all the way around.
Even so, I can't get a screwdriver between the seal and the casing - is this what I am trying to achieve?
I have slid an old bike tyre-puller between the spindle and the edge of the seal but it won't even budge.
Is the seal meant to be this hard to remove?
[Edited on 30/7/06 by Just]
Just
posted on 30/7/06 at 11:38 AM Reply With Quote
Can anyone give me any more guidance to getting the old seal out?
Is there a tool somewhere that can be 'wound' to pull the seal out nice and easily?
DIY Si
posted on 30/7/06 at 11:43 AM Reply With Quote
Hope this makes sense, but you're aiming to get a screwdriver or similar tool on the inside of the seal so you lever one edge of it out. Not sure what type of seal it is, but it may be quite tight and require some effort.
Just
posted on 30/7/06 at 01:16 PM Reply With Quote
Thanks Si, unfortunately the prop-shaft 'spindle' is in the way to get across the seal with a screwdriver.
DIY Si
posted on 30/7/06 at 02:49 PM Reply With Quote
You could try something like a spare spanner. It may have enough curl on the end to reach round the shaft. Or two screwdrivers if you can get them either side of the spindle.
Just
posted on 31/7/06 at 07:01 PM Reply With Quote
Got it out in the end - got a very long screwdriver into the groove, and pushed it forward while hanging out of the side of the car - took a few attempts and a few turns of the screwdriver to keep it straight-ish (that won't be used for screws again that's for sure) and eventually it popped out. The spring was left behind so good idea to check that has come out with the seal.
Now I have to get the new one in, but a 33mm impact socket should do that!
DIY Si
posted on 31/7/06 at 09:03 PM Reply With Quote
See, told you a screw driver would do it!
Just
posted on 1/8/06 at 11:47 AM Reply With Quote
Yep, good call on the screwdriver - in the end the 99p shop furnished me with one long enough and thin enough to get in at it.
Just
posted on 1/8/06 at 05:27 PM Reply With Quote
Now I can't seem to get the new one in!
I am using a large socket and a decent sized hammer and with a fair amount of swinging, the seal just pivots one way them the other. I can't get the whole thing to go in level - and with one side in, the others won't budge.
Just
Do I need to hit it quite hard or should it just tap in evenly?
[Edited on 1/8/06 by Just]
NS Dev
posted on 1/8/06 at 05:48 PM Reply With Quote
Did you get the whole of the old seal out including the metal outer casing? Just wondered as you said the spring came out?
Anyway, if you did, yes the new seal usuall tips up as you try to tap it in, basically get the big socket squarely on it, get it resting gently and squarely in place on the end of the gearbox, then BATTER it one straight and hard with the hammer!!! not a job to be timid with, but you need to keep it square as you hit it!
posted on 1/8/06 at 06:00 PM Reply With Quote
A smear of grease on the outside of the seal often helps if they are especialy tight.
Just
posted on 1/8/06 at 06:43 PM Reply With Quote
Thanks, the problem is I can't get a really good swing at it - do I need to get the rear end up quite high perhaps?
The seal just pivots no matter how hard I manage to swing at it, the little rubber edging on the back of the seal is get scuffed off too.
Just
posted on 2/8/06 at 06:44 PM Reply With Quote
Well, managed to get it in tonight quite easily using a 4lb number one tool!
Put some blue gasket sealant all round the edge too to make sure.
In the end, the lessons I learnt were;
To get it out - get a long thinish screwdriver around the spindle and into the seals inner edge (enough to catch the metal casing of the seal from the inside). Then swing on it as hard as you can to pop the seal out.
To get it in - a bit of oil or grease on the outside of the case, and the inside ready for the propshaft. Large socket as a drift (34mm Halfords Impact I used) with an extension bar to help get at it with the hammer and then wack it straight in with a 4lb baby sledge!
NS Dev
posted on 2/8/06 at 10:50 PM Reply With Quote
.............well I did say "BATTER it"!
LOL, as long as it stays square and you don't slip a good whack won't hurt it!
well done mate!
