Author: Subject: Pug 306 judder
cadebytiger
posted on 23/8/06 at 04:57 PM Reply With Quote
Pug 306 judder
Don't know if any of you have a 306 or have come accross this problem before but i have brake judder under light braking about 40mph.
It is comming from the rear as when the handbrake is put on it judders also.
all new disks and drums. I am at a loss.
Could it be the rear hubs? or some kind of susspension thing?
Any help would be great!! Sorry it's off topic but noone seems to have a clue!
Rupert
Danozeman
posted on 23/8/06 at 05:01 PM Reply With Quote
Rear beam bushes?? Pad loose in the carrier??
Can you fell it through the brake pedal or does it just make the car judder?
Dan
cadebytiger
posted on 23/8/06 at 05:02 PM Reply With Quote
you can feel it both through the car and the pedal i would have said
Rupert
t.j.
posted on 23/8/06 at 05:07 PM Reply With Quote
at the rear the axle-frame is attached with an rubbermounting to the trunk. These come often get torn. Look if these are in healty condition.
If so, Are you really sure that the discs are not screwed up?
zetec7
posted on 23/8/06 at 05:18 PM Reply With Quote
Still sounds like lateral runout in a brake rotor to me. Also - check for any fluid leakage onto the rotors. A drop or two of brake fluid or other lubricant (particularly silicone brake grease!) inadvertantly left on the rotor will do this, for sure! Even a greasy fingerprint on the rotor surface while installing will cause this.
UncleFista
posted on 23/8/06 at 05:36 PM Reply With Quote
Check the rear calipers where they seat to the hub, the ally can oxidise under one side and push the calipers away from the hub, making them no longer inline with the disks IYSWIM
PS Any chance of calling brake disks errr, "disks" instead of "rotors" ? Just seems to make sense to me to speak English on an English server, 'specially if you're English, like...
[Edited on 23/8/06 by UncleFista]
Tony Bond / UncleFista
Ketchup
posted on 23/8/06 at 05:46 PM Reply With Quote
check to see if its got a rear brake compensator, these can sieze, when mine starts to stick on my 405, which happens quite often, it makes the rear brakes pulse a bit
Markp
posted on 23/8/06 at 05:59 PM Reply With Quote
this happened on my corsa when the rear wheel bearing had gone
ATB Mark
stevec
posted on 23/8/06 at 08:05 PM Reply With Quote
"quote" PS Any chance of calling brake disks errr, "disks" instead of "rotors" ? Just seems to make sense to me to speak English on an English server, 'specially if you're English, like...
I second that, we will be spelling tyre wrong and calling bonnets hoods before you know it.
posted on 23/8/06 at 08:16 PM Reply With Quote
See if you can get the car put on a brake roller tester , should show up any fluctuation quickly.
Dusty
posted on 23/8/06 at 10:03 PM Reply With Quote
I would go with the beam mounts. Sort of family thing with Pugs over several models.
Chippy
posted on 23/8/06 at 10:21 PM Reply With Quote
I see from your post that you have fitted new drums to the rear. Some years ago I purchased new drums for my old AX, (long gone to the breakers), had much the same problem, turned out to be a faulty drum, turner slightly out of centre, exchanged it problem solved. Not saying yours is the same, but worth a check. Regards Ray.
Phil.J
posted on 24/8/06 at 07:58 AM Reply With Quote
Just to be pedantic, 'disk' is actually spelt disc in the UK. 'Disk' is the American spelling that has crept over here with computer usage.
cadebytiger
posted on 24/8/06 at 09:10 AM Reply With Quote
Thanks for the tips but the car was doing it before we changed the drums too (thats why we changed them). Thanks for the help! This forum really is invaluable!
Rupert
cadebytiger
posted on 24/8/06 at 09:11 AM Reply With Quote
This seems to have cropped up over and over. I will have a check at the weekend. Sorry to be ignorant but what am i looking for?
Rupert
jonbeedle
posted on 24/8/06 at 09:14 AM Reply With Quote
Is it a noise or a vibration? I have a 306 estate which makes a juddering sound under braking and it's the exhaust banging about on its rubber mounting.
"Everyone is entitled to an opinion however stupid!"
cadebytiger
posted on 24/8/06 at 09:18 AM Reply With Quote
No its a real vibration through the whole car.
cadebytiger
posted on 24/8/06 at 09:37 AM Reply With Quote
They have a brake tester when you do an MOT don't they. Would this sort out brakes from beam mounts?
Rupert
Danozeman
posted on 25/8/06 at 05:58 AM Reply With Quote
Yep. Itl make the gauge wobble if uv got a oval drum ot warped disk. Most garages will put it on the rollers for small money. Youl soon see if its the brakes.
If u get underneath and see if theres any movent in the beam bushes or any splits etc.
Dan
cadebytiger
posted on 25/8/06 at 01:21 PM Reply With Quote
Thank you! I will take it down to the local garage!
Rupert
