Author: Subject: compact v8/v6
posted on 19/3/07 at 03:49 PM Reply With Quote
compact v8/v6
what is the smallest most compact v8/v6 engine around?
and how small? (height,width,length)
needs to be easily avavalaible & cheap, all alloy, deliver 200 bhp as standard.
clockwork
posted on 19/3/07 at 04:08 PM Reply With Quote
ls6
With regards to size, with/without the gearbox?
[Edited on 19/3/07 by clockwork]
Mal
posted on 19/3/07 at 04:09 PM Reply With Quote
Most Compact V8
I would say it is the engine made by a company in the Poole area which uses a pair of R1 engines mounted on a common crankcase to form a V8.
I don't think it meets your price criterion though.
3GEComponents
posted on 19/3/07 at 04:27 PM Reply With Quote
V6 has got to be VW's VR6 lump, this has stuffed into the front of a MK1 Golf.
V8? The old rover lump is still hard to beat for size.
RazMan
posted on 19/3/07 at 05:07 PM Reply With Quote
Duratec V6 & MTX75 gearbox?
Raz
DIY Si
posted on 19/3/07 at 05:17 PM Reply With Quote
Might depend where you want to put it. RV8 isn't actually that big, but in the boot it will be, due to a transaxle. In the front, plenty(ish) of space. If you have room for a transaxle, the audi V6's aren't that big and fairly powerful, esp. the twin turbo version!
Sun Tzu, The Art of War
mfp-66
posted on 19/3/07 at 05:22 PM Reply With Quote
compact v8
the daimler v8 is prob the smallest but its old and fairly hard to get parts for.
the ford 5.0 is smallish (less than a rover) and as standard produces 200hp from a mid eighties engine not that heavy if fitted with alloy heads & inlet. parts are cheap from the states
oadamo
posted on 19/3/07 at 05:33 PM Reply With Quote
v6 24v scorpio bob engine 210bhp standard size:2ft 2ft 2ft without gearbox theres one in a breakers by me
seen it running very good he wants 150 for it its got a auto box with it
adam
Mr G
posted on 19/3/07 at 07:33 PM Reply With Quote
If i'm not mistaked the vw vr6 lump is'nt a v6 but a staggered six
Wadders
posted on 19/3/07 at 08:14 PM Reply With Quote
Lexus/Soarer can be had for not a lot of dosh, there was one on ebay a couple of weeks ago for about £600 Buy it now.
Ford 302 is about the smallest, although, as said not exactly light unless you throw some dosh at it.
Guess the good old RV8 will be the cheapest.
If i wanted a V6 i'd look at the alfa. Gorgeous looks and sound, and fairly cheap
If your brave/mad like me, go out on a limb, and look for something different (see left) very light, compact, 7500 rpm redline, 400hp as standard and dry sumped into the bargain Bit of a challenge to get running and mate to a gearbox tho.
Al.
posted on 20/3/07 at 08:03 AM Reply With Quote
what about the engine form the Rover 827? - think it is same as honda v6 - is that small?
ned
posted on 20/3/07 at 09:51 AM Reply With Quote
audi v8's are generally very short as they hang over the front axle, not sure on the width or other dims though.
Ned.
ps what about the small mitsibushi v6 (2ltr?) out of an fto? there was also a 1.8 or 2ltr v6 fitted in mazda mx3's iirc?
[Edited on 20/3/07 by ned]
beware, I've got yellow skin
NS Dev
posted on 20/3/07 at 11:51 AM Reply With Quote
what other criteria?
Most compact "car" v6 around is the Opel-Cosworth KF V6, 450hp at under 90kg all-up weight and tiny.
Really small would be a 2 stroke v6 outboard boat engine, just as a daft answer, but the little v6 Yamaha outboards make huge power from very small cc!
andyps
posted on 20/3/07 at 01:26 PM Reply With Quote
What about the engine from the Mazda MX3? No idea how big it was but should be pretty compact for a V6 as it was only 2 litre.
NS Dev
posted on 20/3/07 at 05:15 PM Reply With Quote
pretty much same as ford/jag baby v6
locost_bryan
posted on 23/3/07 at 04:18 AM Reply With Quote
Mazda MX3 V6 totally unrelated to Ford/Jag V6.
K8, 1800cc, 130 or 140bhp, MX3
KF, 2000cc, 140 or 160bhp, Eunos 500
KL, 2500cc, 165 or 200bhp, MX6/626/Telstar/Probe
620l x 675w x 640h
176kg
Suzuki V6 based on it.
[Edited on 23-3-07 by locost_bryan]
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
Ringius
posted on 17/4/07 at 07:53 PM Reply With Quote
Audi V8
Hi, info on Audi V8 as found on net (don't know whether it is 3.6l or 4.2l engine, I do believe that they share the same block though...)
1. 20-1/2" = 521mm
2. 29" = 736mm
3. 19" = 483mm
4. 11-3/4" = 298mm
21" = 533mm
1:the length " from the pullies to the transmission matting surface".
2:width top
3:width bottom
4:from the front to the engine mounts.
Weight 440 lbs (est 400) (198kg)
[Edited on 17/4/07 by Ringius]
Volvorsport
posted on 17/4/07 at 09:34 PM Reply With Quote
the 60 degree renault v6 used in the laguna/clio etc are pretty compact .
the good ole PRV(in later form) aint too bad either and comes with a RWD gearbox .
www.dbsmotorsport.co.uk
getting dirty under a bus
