Author: Subject: wheel studs (what length??)
pick
posted on 12/6/07 at 04:56 PM Reply With Quote
Hi just wondered if anyone could tell me what length wheel stud they use or I will require in a cortina front hub and also in a sierra rear disk hub for use with a mini light style wheels?
Shaw
twybrow
posted on 12/6/07 at 05:02 PM Reply With Quote
I have the longest possible. Plan is to build up the bodywork, then look at how big the spacers need to be to maximise the track. Then cut the studs down if needed (which will be fun!).
RazMan
posted on 12/6/07 at 05:58 PM Reply With Quote
I think the golden rule is something more complicated but I like to have at least 8 full turns of the nuts - ideally 10. So you will have to measure the hub thickness, and the wheel boss thickness and take it from there.
Raz
pick
posted on 13/6/07 at 06:29 AM Reply With Quote
Hi , thanks for the advice much appreciated
