John.Taylor
posted on 13/8/07 at 12:47 PM |
Having trouble bleeding brakes...
I'm having trouble bleeding my newly installed brakes (new Sierra Bendix mc, reconditioned Sierra callipers front & rear, and new lines).
If I leave them for a while then press the brake pedal it goes down approx half of it's original (non filled) travel before it goes hard and can
be moved no more. If I pump it, it goes significantly stiffer, but not to my liking. I've been told that this is a sign of air in the rear
lines, trouble is, I've now run the fluid through several times both with an eezibleeder and with my father pump the pedal up before I release
the nipple, but the air isn't coming out and I now think that my fluid may be no good due to the workout and air exposure it's had.
I was wondering if the ATE super blue stuff would pass SVA as it isn't Dot approved due to the colour? At least I could see when I'd bled
new fluid through with this stuff.
shortie
posted on 13/8/07 at 12:54 PM |
Have you turned the rear callipers upside down and then tried bleeding them??
Rich.
nige
posted on 13/8/07 at 01:01 PM |
try bleeding the m/c first
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
John.Taylor
posted on 13/8/07 at 01:08 PM |
The calipers are the correct way around at the rear with the nipple facing upwards - I know this because they weren't last weekend when I first
tried bleeding the system and I got no pressure whatsoever.
Swapping sides this weekend so the nipples face up has made a huge difference, subjectively increasing braking from 10% you could just push it with
the brake pedal pushed, to 60% is whereby two people can't push it with the pedal down (held by a wooden stake against the chasis) but the pedal
still goes halfway down until pumped.
How do you bleed the MC alone?
welderman
posted on 13/8/07 at 01:17 PM |
if your wanting a lift, let me know, i can pop round most nights.
Thank's, Joe
I don't stalk people
John.Taylor
posted on 13/8/07 at 01:50 PM |
I'm going to give them another bleed tonight or tomorrow (subject to HWMBO) and if they're still playing up I might take you up on that
offer.
I'm a bit short on helpers at the moment since my keenest friend is due to be a dad any day now (was expecting a baby on 9th August but
it's overdue), and my father's just gone on holiday for two weeks.
Pumping the pedal, chocking it with a stake and running around the car is wearing a bit thin.
I'll send you a u2u if I need some assistance.
welderman
posted on 13/8/07 at 02:00 PM |
okaydokay mate .
Thank's, Joe
2b_pablo
posted on 13/8/07 at 02:15 PM |
get a little one man bleeder it has a one way valve so you attach to the nipple, loosen the nipple then give a few pumps, go back and tighten the
nipple.
pain in the arse but better than a bit of wood as you get a good bit of fluid through the pipes.
did you shake the bottle before pouring fluid in?
posted on 13/8/07 at 02:38 PM |
I've found an Easybleed works well.... just don't use too many PSI or it can knacker the MC seals....
Taping the caliper whilst bleeding worked for me... It released a whole load of bubbles. Not sure where they were hanging out but the brakes felt much
better afterwards!!!!
I think the worry about the fluid is unfounded. If you're refilling the Easibleed with the drained fluid it may have some moisture in it but not
enough to cause that degree of sponginess initially. It sounds very much like air in the system. Then again, if you are re-using the fluid I'd
wait until it's fully bled (ie no air) then re-bleed it with fresh fluid.... Have you got anywhere an air bubbles could hang out- like a
hydraulic brake light switch???
John.Taylor
posted on 13/8/07 at 03:10 PM |
I've got a switch off a tee on the footwell by the gearbox. I slackened it off to bleed it like a nipple, is this correct?
The Eezibleeder was ok for getting fluid into the system, but pumping the pedal made it better.
I'll give the calipers and MC a tap when I re-bleed them.
[Edited on 13/8/07 by John.Taylor]
posted on 13/8/07 at 03:38 PM |
Key thing is pump the pedal S-L-O-W-LY
Yes easzibleed is a good tool but even with it the pedal has to be pumped a couple of times AND the pedal held to the floor while each nipples is
closed.
if the above dosen't work.
Remember also the handbrake cable has an effect on the foot brake, leave the cable fully slack until the hydraulics are fully bled.
Operating the foot brake should then ratchet up the self adjusters. If that dosen't work set the rear brake adjustement by operating the
adjusters manually.
Also
If any of the calipers are not presenting the pads 100% true to the discs this will cause a spongey pedal.
If you have proper OEM style "rubber" flexible hoses it is often useful when trying to track down the cause of a sponegy pedal to clamp
each hose in turn and try the pedal.
higgsti
posted on 13/8/07 at 06:08 PM |
try putting a piece of metal between caliper which is same thickness as disc ,then take caliper off and suspend lower.you might not be getting all the
air out because you mastercylinder is lower than caliper unlike on the car
RazMan
posted on 13/8/07 at 07:58 PM |
I found exactly the reverse Short & fast pumps by a helper while you are attending to each caliper. It whooshes any air bubbles straight out
and they don't get a chance to get lodged somewhere (like a switch)
Eezibleed was too slow for me and has left trapped air every time I have used it.
Raz
posted on 13/8/07 at 08:18 PM |
Problem with fast pumps is that it is not unknown for some master cylinders to draw air in past the seals on the return stroke --- this was always a
big problem with ATE systems.
In fact the only way to bleed some Teeves clutch systems was to pressurise from the top down using an easzibleed or similar to keep the seals expanded
durring the suction stroke.
Other thing about slow pumps is it keeps the air pockets in big slugs rather than producing microbubbles that can lodge within the system.
A good trick if a system is difficult to bleed is working one wheel at a time to take the pads out pump the caliper pistons out a little, clamp the
flex hose and push the pads back venting excess fluid via the nipple.
NS Dev
posted on 14/8/07 at 11:52 AM |
Yes, do bleed the switch as you have done.
next, is the pedal "springy" or "spongy"
It could well be springy due to the pads not being bedded in.
If you are expecting a rock hard pedal, you need to drive it a bit first and bed the pads in.
My pedal had a long travel for the first 50 miles or so but its great now.
