Author: Subject: Pinto 205 block, what makes them so special????
eddie
posted on 19/9/03 at 06:45 PM Reply With Quote
clues in the question....
plus what did they come from????
Please feel free in advance to: correct, update, ridicule or laugh and point at any comments made by myself in this post....
rell
posted on 19/9/03 at 06:58 PM Reply With Quote
the cortina and capri blocks were cast thin but the 205 block was cast thicker so you can bore it out to 93mm even 94 at a push (race engine what will not do very many miles).
eddie
posted on 19/9/03 at 07:10 PM Reply With Quote
what cars did they fit them to???
and how can you tell them apart????
[Edited on 19/9/03 by eddie]
rell
posted on 19/9/03 at 07:19 PM Reply With Quote
sierras and transits (some older sierras blocks are still the old block)
chrisg
The big "205" cast on the side is a bit of a clue, 89 onwards 2.0 litre Sierras and Granadas
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Browser
posted on 19/9/03 at 08:13 PM Reply With Quote
Hasn't someone else asked about this recently? The 205 block grew out of the Sierra Cosworth project, as the original cars used standard Pinto engine blocks which proved to be a little weak in some areas (suprise suprise!) and so Cosworth modified the design of the block slightly to the 205, and Ford adopted it as their standard item.
eddie
posted on 20/9/03 at 11:10 AM Reply With Quote
Ho Ho Ho
OK some of us are less familiar with ford products (mis-spending our youth on 'A Series' power such as mini's and the likes)
Mark Allanson
posted on 20/9/03 at 05:19 PM Reply With Quote
Eddie,
Basically, look for a 2.0i Sierra, I think they all had 205's and an unleaded head.
I am still trying to find out the safe rev limit for one in standard trim - my lowered EFI thingy will increase the revs at which peak power will be produced - just hope is is below the safe rev limit!
VinceGledhill
posted on 3/10/03 at 04:13 PM Reply With Quote
According to book I've just bought "How to power tune Ford OHC Pinto.... etc..." by Des Hamil. The bigest weak point on the 2.0 pinto is the Con rods which are reliable to about 6,700 RPM. So looks to me that a rev limiter set to 6500 would be about right.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
James
posted on 3/10/03 at 04:33 PM Reply With Quote
http://www.pumaracing.co.uk/pinto.htm
Has some inteesting stuff about it.
HTH,
James
ned
posted on 3/10/03 at 04:47 PM Reply With Quote
vince, might want it a bit lower for reliability, incase you miss a gear or are going for it big time on downshift!
Ned.
beware, I've got yellow skin
VinceGledhill
posted on 4/10/03 at 06:00 PM Reply With Quote
Good point well made Mr Flanders.
Regards
Vince Gledhill
steve m
posted on 5/10/03 at 02:12 AM Reply With Quote
6500 rpm ??
to low for me
8000, on a xflow was good
for 5 seconds then "bang"
lots of smoke tho
Mark Allanson
posted on 5/10/03 at 08:27 PM Reply With Quote
I considered using a Fiat FIRE engine for a while, if you used the cam and carb from a 4x4 (low compression and long duration for torque) in the high compression Uno/Panda unit, it has about 65BHP, revs to 8000 freely and will do this reliably all day, is light enough to put in the car by hand, just couldn't find a gearbox to mate it to - perhap Nick davidson knows one?
accident
posted on 9/10/03 at 12:59 AM Reply With Quote
as an answer to "whats so special about a 205 block?"
NOTHING!.
the 205 block is just as weak and weady as all the other pinto blocks that preceded it.
the 200 block was quite good(4x4 cossie)it had thick enough walls on all the bores
ChrisW
posted on 9/10/03 at 07:24 AM Reply With Quote
Was going to say the same thing - can't remember where I read it tho (havn't got the book you mention)
Chris
[Edited on 9/10/03 by ChrisW]
My gaff my rules
Noodle
posted on 9/10/03 at 08:39 AM Reply With Quote
Originally posted by steve m
6500 rpm ??
to low for me
lots of smoke tho
Standard 1996 Nissan Primera 2.0eGT engine: 8600rpm and still rising. Practically indestructable. RWD gearbox from 200sx should fit. It will rev-high all day without complaint.
Neil.
accident
posted on 12/10/03 at 02:03 AM Reply With Quote
ah but then you get into the nightmare that is 200sx clutches.
they are all crap
[Edited on 12/10/03 by accident]
Noodle
posted on 12/10/03 at 08:08 AM Reply With Quote
they are all crap
Interesting. Care to elaborate?
Neil.
accident
posted on 13/10/03 at 10:25 PM Reply With Quote
current winter car is an s14 200sx.
now its a cheap rwd car with all the toys.
and as long as you throw away the standard exhaust(standard tube is the worst exhaust ever) its a fun car.
needed a clutch so i bought the cheapest.
it slipped at tickover.this is at 200 bhp maybey a little more but not much)
so i fitted a LUK clutch(still in the cheap and nasties) and that only slips if i hit the power hard.this is with crap rear tyres not slicks.
now i could change to a paddle clutch 300 quid plus and lose drivability(this is after all my comfy car not my fun blade locost)
ive run sierra's at double this power on standard plates ad they slip less.
im in the process of having a flywheel machined to take a modified ford cover(and lose some of the massive wieght)will give heavyer pedal but hopefully no slip
[Edited on 14/10/03 by accident]
