pick
posted on 20/11/07 at 09:08 AM |
Power Commander Lean Map for Honda Blade 954?
I finally have received the pc3 USB for my engine. I now need to find a ‘Lean’ map for it so hopefully I can get my car through the SVA on its second
attempt! Is it a case of going to a tuning centre and getting them to set it up for the test and then take it back to be set up again when it has
passed or is there somewhere I can down load a lean map for it?
Shaw
worX
posted on 20/11/07 at 01:47 PM |
Hi Shaw,
You could call dynojet in the US, they helped me out with a custom map on my 600RR when I had stuff on it that was only just out.
And you could also lean it off yourself using a laptop and the software...
pick
posted on 20/11/07 at 08:20 PM |
Cheers Steve,
I'll have a closer look at the software I just just worried about possibly damaging the engine by running it too lean ....(if
this is possible with a power commander!)
Shaw
