Author: Subject: Autoprop UK prop bhp rating
Lars
posted on 21/11/07 at 07:14 PM Reply With Quote
Hi
Does anyone know how many bhp I can put through an Autoprop propshaft?
Mine uses 2" tubing, and I seem to remember that there was some sort of limit.
Just wondering to check if it will be OK to use with a zetec, possibly with turbo.
Or is there anyone who has run an Autoprop propshaft with a zetec?
Lars
blakep82
posted on 21/11/07 at 07:16 PM Reply With Quote
try it. if it breaks, lesson learned
I think it should be ok with a zetec with a turbo. though i don't know if there's a max bhp. maybe ask the manufacturer what they recommend?
________________________
Lars
posted on 21/11/07 at 07:17 PM Reply With Quote
yes, if no-one knows i'll give them a call tomorrow
SeaBass
posted on 21/11/07 at 07:22 PM Reply With Quote
My propshaft manufacturer implied that power and torque handling should be determined by the UJs as the tubing should be fine.
iank
posted on 22/11/07 at 12:06 AM Reply With Quote
Would it not depend on diff, tyre stickyness as well as torque/bhp?
Anonymous
speedyxjs
posted on 22/11/07 at 07:25 AM Reply With Quote
And maybe RPM?
blakep82
posted on 22/11/07 at 08:19 AM Reply With Quote
as well as the tube itself not sure a 14mm diameter tube, with 0.6 wall thickness would last long.
I think you need to take everything into account.
2" tube though, at a guess i'd say 300bhp maybe?
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 22/11/07 at 06:43 PM Reply With Quote
The length is important. The shorter the shaft the more power.
I would use 2" tube for a prop up to about 500mm overall length if the engine had up to 100bhp.
Any more than this I would go up in tube dia.
Lars
posted on 22/11/07 at 09:45 PM Reply With Quote
Spoke to them today and was told that there is no specific rating.
They build it based on what people say their engine and application is when they order.
For stronger props they will use larger/stronger uj's, but (as I understood it) the tube remains the same, at 2".
(However they now use slightly thicker tube, but was unable to tell me what mine was made of.)
Lars
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
posted on 23/11/07 at 03:20 AM Reply With Quote
I used tube thickness of either 0.095" or 0.064"
NS Dev
posted on 23/11/07 at 12:55 PM Reply With Quote
I use a 2" x 600mm ish prop in my locost with 200hp........................
Its what caterham used in all their HPC's with the same engine, mines a retubed caterham one.
Lars
posted on 25/11/07 at 02:06 PM Reply With Quote
Just measured mine and it is also about 600mm.
If it fails is it likely to snap or will it slowly wear out the uj's?
NS Dev do you know what thickness yours is? Or how much it weighs?
