Author: Subject: Fitting Aeroquip Oil Cooler Hose Ends
Avoneer
posted on 27/11/07 at 07:42 AM Reply With Quote
Anyone got any tips for fitting the push on connectors onto the rubber hose.
It's a bit tight to say the least.
Pat...
posted on 27/11/07 at 08:54 AM Reply With Quote
no sure which ones you refer to but there are quite a few.
there are some that have barbed end (aka fir tree fitting) that are supposed to be pushed on and that is it - so yes, it would be a tight fit - sound like your ones.
using some oil and warming up the hose in some hot water to soften it should help it get on with a twisting
& pushing motion.
if you have angled fittings on each end, mark the hose and connector so that you end up aligning them correctly. I found once you stop twisting the ends on, they get quite hard to twist hence the need to stop when they are in correct position.
although you don't need to put clips on, I did for peace of mind.
martyn_16v
posted on 27/11/07 at 10:55 AM Reply With Quote
Hairspray. Slippy when wet, dries pretty sticky
Avoneer
posted on 28/11/07 at 10:00 PM Reply With Quote
I tried hot water and oil, and got them past the two barbs, but just can't get them the final 10mm.
Any further ideas???
Pat...
thomas4age
posted on 29/11/07 at 09:50 AM Reply With Quote
I always spray a little wd40 in the flange the hose needs to go over, the slide on pretty easy, but are a nightmare to get of again once dried out. never popped a hose in action though.
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 29/11/07 at 05:00 PM Reply With Quote
Yes they are difficult to get on.
I soak the hose in very hot water, clamp the fitting tight in the vice, lube everything up with engine oil and really go for it in one go.
Doing-12 fittings was not easy..........
ChrisGamlin
posted on 29/11/07 at 07:16 PM Reply With Quote
As suggested by Martyn, Id give hairspray a go. Ive not used it on hoses but its brilliant for putting handlebar grips on mountain bikes, allows you to position the grip quite easily then sticks it on once it dries.
