Author: Subject: rose joints
oadamo
posted on 31/12/07 at 09:08 PM Reply With Quote
rose joints
mcgill sells 5 for £11 are these the ones that everyone uses for there cars. or do you have to buy the better ones.
adam
nitram38
posted on 31/12/07 at 10:01 PM Reply With Quote
Your description is as clear as my head right now!
A few more details like sizes would be a good starting point!
oadamo
posted on 31/12/07 at 10:18 PM Reply With Quote
1/2 x 1/2 unf.heres the bay number 190185486791.
adam
cidersurfer
posted on 31/12/07 at 11:03 PM Reply With Quote
That does seem incredibly cheap. I paid about £18 each last year for mine, which I think were Aurora. The daddy are NMB which are about £45 each but they are proven by race teams and I've heard of the cheap ones being all done following a single track day. Depending upon what you're using the car for, you should spec the rose joint to suit. If you're using them in your suspension, then it's worth factoring in how much it costs to get the suspension properly set up if you're using cheaper bearings which could potentially fail more frequently. So, I went for a mid-range solution...
shimming solid lifters is a job for a friend...
nitram38
posted on 31/12/07 at 11:28 PM Reply With Quote
I have used Mcgill for the same size rod ends on the F1-2 with no problems after 1500 miles.
He is very good on price.
Just remember to check them regularly and you should be ok.
oadamo
posted on 31/12/07 at 11:40 PM Reply With Quote
ive just bought some so ill see what there like. i could always upgrade them later if they fail.
adam
Nick Skidmore
posted on 1/1/08 at 10:24 AM Reply With Quote
With rod ends (unless you are getting a known quality at a 'special offer' price) you get exactly what you are paying for.
Cheap = poor quality and durability.
Expensive = good quality and durable.
Buy the very best you can / can't afford they are cheaper in the long run.
[Edited on 1/1/08 by Nick Skidmore]
RazMan
posted on 1/1/08 at 11:19 AM Reply With Quote
As Nick says, you definitely get what you pay for.
£25 each is about right for quality PTFE lined rose joints that will last more than a few thousand miles.
My £12 cheapies only lasted 5K miles so I went for the NMB jobbies which have lasted twice that and still going strong.
Raz
mark chandler
posted on 1/1/08 at 01:51 PM Reply With Quote
Mine are the same as these and have done a bit of work now, still nice and tight, @ £3 each you cannot complain.
It keeps the build cost down, I recon you will need around 20 for a fully jointed system which is £60 for these opposed to £800 for some high range jobbies....
Okay they will expire earlier on but it then this cost becomes development and you know if the maths are right on the handling front.
oadamo
posted on 5/1/08 at 04:46 PM Reply With Quote
i had them come this morning. let me just say i can see why there £11 lol i wont be using these on my wishbones. theres slop in the balls already. if you shake them you can here them rattle.
adam
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 6/1/08 at 06:49 PM Reply With Quote
Buy cheap buy twice.........
I am sure over a long time the cost of joints works out similar........ buy lots of cheap ones or expensive ones once, especially if you factor in the time taken to replace when you could be earning cash or having fun.
A cheap joint will not last as long and be weaker. Often you could buy a smaller, more expensive joint that will be as strong as the larger cheap one.
I bought NMB because I didnt want to change my joints after a few thousand miles, but theres 26 joints on my car at an average cost of £40........
