mackei23b
posted on 3/1/08 at 11:35 AM |
ZX9R Main Jet Size?
Hi there
I've got a ZX9R C1 engine with a TTS sausage air filter and an MK 4-2-1 exhaust fitted.
I've got a dynojet kit, but I'm after some advice, if you have a similar set up what size of main jet and needle setting did you use?
Any advice greatly appreciated.
Ian
mistergrumpy
posted on 3/1/08 at 11:36 AM |
Roadrunners a good one to ask for this Ian. I think he had the same set up and ended up going back to the standard jets. I'll see if I can find
the thread.
I think 155 seems to be the standard size. This
thread is a good read for a start.
[Edited on 3/1/08 by mistergrumpy]
worX
posted on 3/1/08 at 11:46 AM |
I don't know the ZX9R jetting and would usually suggest going with what's been done before, but surely it makes sense that if you've
increased the airflow by fitting a sausage filter and have a slightly better flowing exhaust, then it would be better to increase the amount of fuel
fed in aswell?
mistergrumpy
posted on 3/1/08 at 12:00 PM |
In fact Roadrunner went back to the standard airbox but settled on 185's. With sausage filters I don't think that airflow actually
increases, more decreases as the bike engines tend to like none disturbed air and with a sausage filter the air will be more turbulent as it will be
drawing from around the engine bay area, Not to mention it will be hotter.
rj
posted on 3/1/08 at 01:13 PM |
Hi, I had mine down at TTS for a rolling road setup / install dynojet, I had already blocked off the air corrector holes,(that got it to run, but far
too rich) and tts fitted the 140 main jets & dynojet needles (stage 1 dynojet kit )on 2nd grove from the top, that saw some improvements , then
fitted 144 mains,and droped needles to top grove, not much difference save for a misfire at low revs,tts chap said needles may need to be put back to
2nd grove if bad at low revs, it was so I put them onto 2nd grove the next day. I intend to try the 140 mains again, as 144s didnt show any
improvement but did give it a misfire at low revs. Probably could have done with a bit more time on tts rr, but it was 5.00pm by time we got as far as
we did, so suggest 140 mains ,dynojet needles on 2nd grove from top and block of air correctors .
Mine is a C1 with pipercross sausage filter, Stuart Taylor manifold and std Honda fireblade alloy silencer, hope this helps
roadrunner
posted on 3/1/08 at 07:54 PM |
It is a can of worms really, mine was dynojetted, but missfired at 4500-5000 revs, so took it to Boggs, first thing he did was to remove the air
correctors(Dave thinks that the Dynojet is'nt worth the money)then he went up to 190 jets, i still had a problem though, i swapped the carbs for
a spare set, which improved things (i tried factory settings fist 160 jets i think)it back fired quit alot on overrun, so i was told to try bigger
jets, i now have 185's in as Mr Grumpy said, it runs fine but another visit to Boggs is needed, oh and i now have the standard air box fitted, i
know Marco has had his upto Boggs and Dave fitted 200 jets with sausage filter.
posted on 3/1/08 at 08:49 PM |
i drilled my main to 165, left the rest, and it was a little rich. But i never set it up properly so a little rich was ideal really. I spent about
£1.50 on a 1.65mm drill bit, job done.
matt.c
posted on 3/1/08 at 11:14 PM |
Hmmmmm very interesting.
