Poll: Fuel pipe [View Results]
Rubber
Metal
What are you doing thinking about this when you haven't even finished welding your chassis???
Author: Subject: Fuel pipe
speedyxjs
posted on 18/1/08 at 08:47 PM Reply With Quote
Fuel pipe
Opinions please
blakep82
posted on 18/1/08 at 08:49 PM Reply With Quote
braided lines get my vote, but there's no option for it
________________________
speedyxjs
posted on 18/1/08 at 08:51 PM Reply With Quote
I meant braided rubber sorry
blakep82
posted on 18/1/08 at 09:00 PM Reply With Quote
ah, ok, rubber it is then!
Mark Allanson
posted on 18/1/08 at 09:02 PM Reply With Quote
I voted metal, but actually used both. Galv steel ones though the tunnel and rubber at each end as the pickups. I used steel as the thought of a broken propshaft mincing up anything else was not a good one.
speedyxjs
posted on 18/1/08 at 09:03 PM Reply With Quote
Where is the best place (locost) to get fuel pipe from? I was going to take it from the donor but they were in pretty bad nick
blakep82
posted on 18/1/08 at 09:04 PM Reply With Quote
^ i'd have thought that braided pipes would be more resiliant to a battering by a broken prop shaft
zetec
posted on 18/1/08 at 11:28 PM Reply With Quote
8mm copper from plumbers. Solder some olives on the end if fitting to rubber pipe and no chance of it coming off under pressure.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
DarrenW
posted on 19/1/08 at 12:11 AM Reply With Quote
I used braided. No reason other than i could get some at the time i needed it. Not sure it is more resilient to being battered. If prop lets go theres not mch will stop it, hoops seem to be a good idea.
Ive also used 5/16" kunifer on previous project to good effect.
[Edited on 19/1/08 by DarrenW]
Coose
posted on 19/1/08 at 12:57 AM Reply With Quote
Bloody hell, if you have a broken propshaft I think you should be worry about more pressing things than your fuel pipe material, such as the condition of your limbs!
Spin 'er off Well...
907
posted on 19/1/08 at 08:18 AM Reply With Quote
I've used 1/4" copper / nickel. (Kunifer)
I needed some for the clutch line, so I used up the rest of the roll for the fuel line.
Flared the end with a brake flare tool.
IMHO if you use metal it's "fit and forget."
Paul G
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 19/1/08 at 08:49 AM Reply With Quote
Fuel Lines
I would vote for braided PTFE, NOT rubber.
The PTFE is more resistant to fuels especially if a recirculating injection system is used. I am not sure of the exact chemistry but when you recirculate the fuel it can attack the rubber. That is why you will not find any rubber lines in the fuel tank.
Also rubber lines allow the smell of fuel through, PTFE doesnt. This scores points with the enviromentalists!
big_wasa
posted on 19/1/08 at 09:50 AM Reply With Quote
5/16" (8mm) copper / nickel / Kunifer
cheap . used as brake lines on Hgv's.
snapper
posted on 19/1/08 at 11:19 AM Reply With Quote
8mm micro bore copper central heating stuff, you get loads for a few quid and it will take fuel injection pressure.
Even if you are on carbs it's worth running a return to the tank for later then use injection pressure hose or PTFE lined braided to connect up
I eat to survive
I drink to forget
