Author: Subject: GRP .... mishaps and how to fix 'em
paulmw
posted on 20/1/08 at 05:01 PM Reply With Quote
Through out the build my black gel coat panels have picked up thier fair share of scratches. Also, taking the car to MK engineering today I caught the side panel on the floor and a small piece cracked off
Whats the best DIY fix
Cheers Paul
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 20/1/08 at 05:27 PM Reply With Quote
If the scratches are small they should polish out.
Or fill them with gel coat and sand back.
Or spray on high build primer flat and then spray on yur top coat.
Triton
posted on 20/1/08 at 06:24 PM Reply With Quote
Cheers Paul
Hi Paul,
Wet n dry on the scratches but be carefull not to rub thru !! With the broken bit, use a grinder/file or whatever you have to dig the area out to good material clean with acetone to remove any wax etc then use gel coat from CFS called topcoat. Then it's back to the wet n dry and polish up. If the hole is huge it might pay to build the gel coat up in layers to avoid air pockets.
Black is not just black though when it comes to the pigment...some look like dark chocolate!
Ask the lads at MK to ask their grp bods for the RAL number for the black pigment.....sure they will sort it for you.
Mark
COREdevelopments
posted on 20/1/08 at 08:51 PM Reply With Quote
i am in the same situation as my body panels some damage, some were done before i even got them!! anyway i was thinking of using gelcoat too. would anyone know the RAL code to the yellow that GTS use? its the standard yellow.
Rob
mistergrumpy
posted on 20/1/08 at 09:45 PM Reply With Quote
RAL 1004
Triton
posted on 20/1/08 at 09:53 PM Reply With Quote
Ring Alex at CFS...(sound bloke) ask if they can mix you up a kg of top coat already pigmented....and wee tub of catalyst then use it like a filler but only mix a small bit at a time.
Mark
