Author: Subject: aero catch sticking
Steve Lovelock
posted on 20/5/08 at 08:55 PM Reply With Quote
aero catch sticking
I have a set of aero catches on my bonnet which were fitted about a year ago after which I removed the bonnet to store whilst I worked on other stuff. I have just fitted the bonnet again and discovered that one of the catches is sticking and wont close without help from a screwdriver. Has anybody encountered this before? If so how did you solve it?
chriscook
posted on 20/5/08 at 09:17 PM Reply With Quote
I had something similar when fibreglass dust was over everything in the garage. A clean up and some light lubrication (WD40) sorted it.
RazMan
posted on 20/5/08 at 09:44 PM Reply With Quote
There was a fault with some of the early ones. They were assembled incorrectly and were getting stuck at 'over centre'.
I phoned the manufacturer and they sent out some replacements without question. I then figured out how they were assembled, dismantled and reassembled them and ended up with TWO good pairs
Raz
sgraber
posted on 21/5/08 at 12:48 AM Reply With Quote
Well CRAP. I've got one that does that of late. I thought is was my fault, but maybe I need to contact the company directly.
Raz, you mentioned that you were able to take it apart and simply re-assemble it to repair it? Or did you have to file/ream some piece of it?
Being across the pond would make for an expensive replacement from the UK.
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
RazMan
posted on 21/5/08 at 08:50 AM Reply With Quote
Hi Steve, After comparing a known good one to my faulty ones it was obvious that a moulding had been assembled 180 degrees out. I had to drill out some pin retaining goo, press out the pins, dismantle and then reassemble correctly - sounds more complicated than it really is.
Raz
Steve Lovelock
posted on 21/5/08 at 12:31 PM Reply With Quote
Cheers Razman, I'll look into that.
Steve Lovelock
posted on 24/5/08 at 03:24 PM Reply With Quote
WD40 did the job. Feel a little silly for not trying it before I posted on here. In fact, now that my SVA is approaching I seem to be losing my common sense!
