<<  1    2  >>
Author: Subject: Nice transaxles for small cars?
Alez
posted on 27/5/08 at 09:44 AM Reply With Quote
Hi All,
I'm having a first preliminary think about a spaceframe Mini project. I'd like a car mid engine and was thinking about the transmission. Most of these cars use a FWD set, the ZCars VTec for instance being very similar to the Atom and using the Honda Civic engine and gearbox. I don't like this because it makes the engine sit high and quite to the rear. I think the engine position this gives is poor compared to the chain driven ZCars R1 or similar cars. For car engine, I like it Retoga Zetec style:
These use a transaxle from Elite Racing Transmissions. I think Hewland has similar transaxles available as well.
I'd like to have any comments from you.
Any experience with these?
What engine(s) would I want to look at? (I'd like a proven solution I can use for reliable 200 bhp, I was thinking Honda Civic, Toyota 4A-GE, Zetec, Duratec as these are well known.)
Are these LSD diff?
What's a "H pattern dog box"? (I thought Hs were sincromesh and sequentials were dog but I've seen one or two described like "H dog" on the web. I like it quick and sequential as one would imagine.)
Any other makes?
How do I know which transaxle goes well with which engine in terms of adapting it and also in terms of torque? (I'm looking at a 700..750 kg car I'd think, with Mini dimensions, maybe 195 or so tyre width and so on.)
I know these will be expensive to very expensive, but any rough ideas of cost?
Alex
tegwin
posted on 27/5/08 at 09:55 AM Reply With Quote
Thats a pretty tidy setup...I like...
Have you considered the VAG transaxle as shown in the 1.8T passat, Audi A4 etc?
How about simply using the passat/a4 as the donor....you can tune the 1.8T engine to about 350hp if you have the inclination
www.verticalhorizonsmedia.tv
Fatgadget
posted on 27/5/08 at 10:14 AM Reply With Quote
Nice.But 8,000
[Edited on 27/5/08 by Fatgadget]
Alez
posted on 27/5/08 at 10:40 AM Reply With Quote
Interesting..
Is it this one? Not sure the rear would fit in a Mini but looks good for similar enough projects?
Nice.But 8,000
Now that's a show stopper
Alez
posted on 27/5/08 at 10:49 AM Reply With Quote
What do Elises and Exiges use? Just the original gearbox that comes with the engine? i.e. Rover K, Toyota..
worX
posted on 27/5/08 at 11:06 AM Reply With Quote
You can get second-hand hewland gearboxes that may already have ford gearbox mounting adaptors from around 1500GBP but they will need rebuilding aswell...
Minicooper
posted on 27/5/08 at 11:14 AM Reply With Quote
I think it will be very tight for space, the seats would have to be well forward and I'm not sure you would get the overhang of the gearbox at the rear in either
I can do a few basic measurements if you want
posted on 27/5/08 at 11:16 AM Reply With Quote
Beetle or VW camper??
Fatgadget
posted on 27/5/08 at 11:24 AM Reply With Quote
Dont you have to turn those upside down with all the attendant problems or something?
tegwin
posted on 27/5/08 at 11:50 AM Reply With Quote
Dont think you have the right VAG tranny there...
The one I found at my local scrappy (250) was pretty short....
But as has been said...perhaps too long for a mini!
Mr Whippy
posted on 27/5/08 at 11:54 AM Reply With Quote
as far as I can remember thats not the case as seen in formula v cars. Note the later cars 1303 etc have proper suspension as per the 911's with normal UG's on the driveshafts if your not keen on the funny swing axle idea.
[Edited on 27/5/08 by Mr Whippy]
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
finlay
posted on 27/5/08 at 12:00 PM Reply With Quote
can you give any sites they would be on sale on ?
cheers
View User's Profile E-Mail User View All Posts By User U2U Member   finlay 's Yahoo
Alez
posted on 27/5/08 at 12:22 PM Reply With Quote
Originally posted by MinicooperI can do a few basic measurements if you want
Very kind of you David but for now it's just putting together a few thoughts so don't bother just yet. It's more this kind of discussion we are having what I was looking for just now
Alex
Mr Whippy
posted on 27/5/08 at 01:06 PM Reply With Quote
Saab 900, Renault and Audi also have used that layout. You might consider even using an automatic transmission as this will do away with the complex gear lever linkage and will effectively give you instant acceleration at the lights. You can also wire the modern electrically controlled ones up to paddle shifts.
Dusty
posted on 27/5/08 at 03:33 PM Reply With Quote
The beetle/transporter transaxles live with the engine behind the axle and the box in front. So yes you do have to invert if you want the engine in front of the axle. Same with the porsche ones. I'm sure I remember an article in PPC a few months ago which also looked at alfa trannys.
Volvorsport
posted on 27/5/08 at 04:23 PM Reply With Quote
std beetle boxes need strengthening above 150 hp , and for 15 inch wheels .
www.dbsmotorsport.co.uk
getting dirty under a bus
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Volvorsport 's Aim
Ringius
posted on 27/5/08 at 08:55 PM Reply With Quote
The transaxle pic posted
Shows a quattro box, the 2WD box is much shorter, think away the black part of the transaxle and you get approx size. The 016 transaxle (as fitted in Audi 80/100/200 is approx 18" from centre of drive-shaft to back-end, the 01E (A4, A6, ...) is shorter still. If interested, I can upload a couple of drawings of the 016-box into my archive.
As for the beetle transaxle, IIRC - it is possibel to invert(?) the pinion gear and reverse the box without flipping the whole transaxle.
Fred W B
posted on 28/5/08 at 06:23 AM Reply With Quote
See 016 details in this thread
Tha older smaller Audi "80" used a smaller box that may be more suitable for you
cheers
Fred W B
drive train
drive train
[Edited on 28/5/08 by Fred W B]
You can do it quickly. You can do it cheap. You can do it right. Pick any two.
Alez
posted on 28/5/08 at 08:21 AM Reply With Quote
That'd be good news, but from the picture just below it doesn't seem so, that has a smaller black end but then it has another bit attached to the rear of that
Then again that box seems to take a lot more torque than I'm looking for, so maybe that 01E you mentioned is worth a look?
Yes that 016 is definitely a monster I'll need to have a look at the alternatives you have been suggesting.
I've been looking at your thread and that's a very impressive job Well done!
Alez
posted on 28/5/08 at 08:28 AM Reply With Quote
I think this is the one mentioned:
Found here:
http://cgi.ebay.co.uk/Audi-A6-80-100-Cab-V6-Coupe-5-Speed-CDX-Gearbox_W0QQitemZ290154113215QQihZ019QQViewItem
[Edited on 28/5/08 by Alez]
MrFluffy
posted on 28/5/08 at 02:11 PM Reply With Quote
The vw transaxle pinion can be swapped easily to invert the drive direction, I have one here that has a hewland ford adapter plate on it, and it was immediately apparent as soon as the bellhousing was off..
My vote is for the Renault un1, http://www.un1.co.uk/
The ng9 is a bit shorter, but its weaker too, and the un5 renault master variant has a unchangeable and almost unusable low diff ratio.
Cue scruffy mockup shot :-
[Edited on 28/5/08 by MrFluffy]
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   MrFluffy 's ICQ status
Alan B
posted on 28/5/08 at 02:20 PM Reply With Quote
Anyone spot the "Z" bar on this....the opposite of an anti roll bar......allows roll but stiffens both wheels trying move together...
Irrelevant I know...
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger   Alan+B 's Yahoo
Alez
posted on 28/5/08 at 03:23 PM Reply With Quote
Is that not massive for the application in terms of weight, size and torque rating? That box is used for V8 applications all the time I think.. Let's have a look at that NG9
Alez
posted on 28/5/08 at 08:52 PM Reply With Quote
This pic shows the UN1 and NG9 side to side. The NG9 is a lot weaker (likely more suitable in terms of weight), but both look unsuitable because of their length
Found here (Renault Medallion = 21):
http://www.gt40s.com/forum/gt40-tech-powertrain-transaxles/19659-renault-medallion-transaxle.html Rescued attachment UN1.jpg
cymtriks
posted on 1/6/08 at 05:08 PM Reply With Quote
From the original post I think what is wanted is a cheaper transaxle than a Porsche G50 that can be inverted.
I have looked at several forums and done a search for this but apart from the G50 I cannot find any examples of a smaller transaxle being inverted.
The VW Beetle, Renault UN1 and the alfa transaxles are all getting on a bit now. They may well be up to the job but finding one might be an issue!
The obvious choices are:
Audi (which I can find nothing regarding inverting) and Porsche (which can be inverted but it is big, heavey and expensive) and Subaru (not common in 2wd)
Does anyone know otherwise?
[Edited on 1/6/08 by cymtriks]
<<  1    2  >>
