<<  1    2  >>
Author: Subject: Nice transaxles for small cars?
mr henderson
posted on 1/6/08 at 05:29 PM Reply With Quote
Originally posted by cymtriks
Audi (which I can find nothing regarding inverting)
Why would you want to invert it, though? It's already the right way round for a mid-engined car
John
Fred W B
posted on 2/6/08 at 06:07 AM Reply With Quote
To improve the driveshaft angles with a low mounted (dry sump?) engine and a low ride height.
I've never seen or heard of it done on an Audi though.
In my car, with the RV8 sump flush with the bottom of the chassis and 80 to 90 mm ground clearance the drive shft angle is 10 degrees, which I am happy to try
Fred W B
[Edited on 2/6/08 by Fred W B]
Delinquent
posted on 5/6/08 at 01:43 PM Reply With Quote
Fred W B
& if you are making the chassis yourself, why not angle the engine and box downwards a few deg to sit the engine lower in relation to the driveshafts (which is what is happening in my plan)
smart1275gt
posted on 16/6/08 at 08:54 PM Reply With Quote
I've seen Mazda rotary engines bolted to VW transaxles and cope fine upto 150bhp.
Rotary Sandrail Conversion
In a Mini - what's wrong with a rear engined transverse set up? I guess weight distribution, but that's it.
[Edited on 18/6/08 by smart1275gt]
sebastiaan
posted on 21/6/08 at 06:49 PM Reply With Quote
alfasud? this gices you inboard brakes also!
akumabito
posted on 21/6/08 at 09:43 PM Reply With Quote
Can't find any pictures at the moment, but perhaps the Alfa 33 box would be suitable?
sebastiaan
posted on 23/6/08 at 05:51 PM Reply With Quote
33 box is very similar to the alfasud box, but with outboard brakes. Highest powered 33 was the 1.7 16V, with 133bhp.
I don't know how they'll cope with 200bhp and middy levels of traction though...
akumabito
posted on 25/6/08 at 10:08 AM Reply With Quote
Seen a twin-turbo 33 once. 500Hp, kept shattering transmissions like crazy. I guess they'd be fine up to 200 though. This one claims 220Hp and 273NM with 0.8 bar boost. Think the 'box will be fine unless perhaps you mate it to a big V6 or V8.
Still not sure about the size though.
Mehh, stick with the Audi. It's a proven concept.
Delinquent
posted on 25/6/08 at 12:10 PM Reply With Quote
wouldn't really worry about the bhp... I'd be slightly more concerned with the torque figures...
Ratman
posted on 27/6/08 at 04:48 AM Reply With Quote
Remember that the transmission only has to be able to cope with the torque that can spin the rear wheels. In a light weight car this might not be all that much, so 500HP may not put all that much more stress on a transmission than 200HP. I guess it would depend where the weakest link in the tranny is.
thomas4age
posted on 16/7/08 at 12:32 AM Reply With Quote
the renault NG3 boxes aren't weak!
they cope with over 200hp in some formula renault cars over here..... everything in the cars has broken at least once exept the box.
it's small Light strong and has room for almost all 4 and 6 cylinder clutches you can think of..... cheap as chips also. all renault 25 exept the V6's and also all everything pre renault 19 uses them......
grtzx Thomas
If Lucas made guns, Wars wouldn't start either.
<<  1    2  >>
