<<  1    2    3    4  >>
Author: Subject: Susp design - camber gain?
cheapracer
Builder
Posts 156
Registered 29/11/08
Member Is Offline
Photo Archive Go!
Building: The Worlds next big thing of course!
posted on 21/4/09 at 05:18 PM Reply With Quote
Originally posted by kb58
I've found saying something is often pointless even if well-intended. It often causes said dangerous person to get defensive, coming back with an "oh yeah, I'll show you," reply, and crash their car anyway...
[Edited on 4/21/09 by kb58]
Ain't that the truth.
Kurt I'm confused by your signature, is the mid engine book out or not? Or does that refer to Kimini?
It's coming....
kb58
posted on 21/4/09 at 06:28 PM Reply With Quote
That's the Kimini book. The new one is in the works along with the car.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
cheapracer
Builder
Posts 156
Registered 29/11/08
Member Is Offline
Photo Archive Go!
posted on 22/4/09 at 05:29 AM Reply With Quote
Thanks Mate and good luck with it.
It's coming....
Sam_68
posted on 9/1/10 at 05:21 PM Reply With Quote
Originally posted by Syd Bridge
Rollcentres of any type DON'T come into the design process of a road or race car. Anyone telling you that they do, and professing to be a designer, is pulling your whatever.
Whilst I have some sympathy for Syd's position (in as much as the geometric roll axis is a myth), I can state absolutely and categorically that the above statement is incorrect, false, untrue, erroneous, complete-and-utter-tosh, and bollocks.
Whilst (as Syd asserts) cars certainly do not roll about their geometric roll centres, the front and rear roll centres are an important factor in dictating diagonal weight transfer via the sprung mass when cornering, which in turn has a major influence on understeer/oversteer balance.
The roll centre heights therefore have a major part to play in the basic handling balance of the car, and roll centre movement when cornering can cause all sorts of nasty issues, since it will result in variations in diagonal weight transfer as the car negotiates the corner.
I know for a fact (having had detailed personal discussions with them), that a number of very emininent race car designers (including a couple of ex-F1 Chief Designers and several designers of championship winning hillclimb single-seaters) pretty much start off their design from geometric roll centre positions, whenever they're designing a car with significant suspension compliance (ie. everything apart from wings-and-slicks circuit single-seaters), with the geometry focusing on minimising roll centre movement throughout the working range, and everything else - spring rates, tyre widths, ARB rates etc. - developed from there.
In terms of the OP's original question, if you were thinking purely about cornering, you'd actually want the camber agin to be arranged so that the outside (loaded) wheel progressively went into negative camber as it loads up in the corner, as most tyres generate most girp with a surprising amount of negative camber, and you pretty much wouldn't care about what the inner wheel was doing, as it progressively takes less and less of the load as cornering forces increase.
In reality, however, this approach would leave you with unacceptable camber change under pitch (dive and squat) or single-wheel bump, leading to a car that was squirrelly under braking and had uncertain grip under hard acceleration.
Unless you have active suspension, all supension geometry is a compromise and unfortunately it's up to the individual suspension designer to choose his own balance of priorities: there's no wrong and right, which is why the discussions frequently get so heated between people who think that there is...
<<  1    2    3    4  >>
