Outragous Wheelspin!
StrikerChris - 2/9/09 at 11:36 AM
Hi
Went on the car's maiden voyage today(dad drivin due to my predicament )on a mildly moist road.The car seemed to ride very well in comparrison to a westy my mate had,but it'll quite happily light up the tires in 3rd,even at 70+.Is this normal in damp conditions in peoples experience,or is something super wrong?its approx 250bhp,shocks are set on softest setting,and as i said the ride is very good,and 195 something 15 yokohama a539s at 20psi.
cd.thomson - 2/9/09 at 11:43 AM
not got much first hand experience with se7ens so everyone feel free to shoot me down.
From my "younger" days of watching oldschool fords on the strips before getting into kits I would say approaching 500bhp per tonne in the wet would easily light the tyres in 3rd..
tomgregory2000 - 2/9/09 at 11:53 AM
try droping your tyre pressures down to 17-18 psi, bigger contact patch on the road
smart51 - 2/9/09 at 11:53 AM
Yep. My BEC had huge grip in the dry but was very poor in the wet. My Peugeot 107, in comparison, doesn't seem to notice if it is wet at all. Hurl it into corners at indecent speeds and it just hangs on. Perhaps its because sevens are very light with wide tyres and lots of power (relatively).
nib1980 - 2/9/09 at 11:53 AM
doesn't sound unreasonable to me.
i won't take my car out in the damp as It's too twitchy for my liking
Moorron - 2/9/09 at 12:06 PM
first time i took mine out coming off an island at very slow speeds i managed to get it sideways.
I never noticed the difference with cold and hot tyres before i had my 7, now i know it makes the a huge difference.
Again let the tyres down, as low as possible to get the rubber moving and warming up quicker. i also found softening the rear shocks made a difference also.
Take it easy these things hate slippy condition.
mangogrooveworkshop - 2/9/09 at 12:10 PM
Originally posted by StrikerChris
Hi
Yep sounds right......had wheelspin in the dry in third a while back.
Depends on your tyres as well....Ive got some russian made junk that came with the mags and they are good in both wet and dry. But I know of others with fancy street legal slicks that have a poo time in the wet but the dry they are like glue.
Since it rains everyday in this cold mouldy island I stick with the wet/dry combo to stay on the road.
So the answer is just to take it easy....otherwise we will see you posting pix of an off road adventure
mookaloid - 2/9/09 at 12:10 PM
Brand new tyres in the wet isn't a particularly good idea. You should find that the wet performance will improve after they have had a few miles in the dry - also tyre pressures as mentioned above
wilkingj - 2/9/09 at 12:29 PM
Sounds about par for the course.
This is why we all say TAKE IT EASY until you learn how your car drives.
I have a V8, and as soon as its damp, it becomes very tail happy. Mainly down to loads of power and torque. Its easy to break traction, then spin it into a ditch or wall, or tree, etc etc.
Take it steady, and watch out on damp roads, and worse still are damp patches under trees, hedges, and areas of shade where it hasnt fully dried out when the rest of the road appears to be dry.
There is very good reason why everyone plugs the TAKE IT EASY message. Also concentrate on your driving and look at the road / surfaces / cambers / pot holes as well as the traffic.
Maybee, I'm teaching Granny to suck eggs etc etc... But plenty of newbies will read this, so its aimed at everyone.
contaminated - 2/9/09 at 12:46 PM
As all of the above. Mine spins in third in the damp (225 Bridgestone Potenza's probably don't help) and round corners my Megane gets the job done quicker in the wet!
l0rd - 2/9/09 at 12:58 PM
I wouldn't be surprised at all. I do not have experience in 7s yet, but i could do the same with my pick up truck in Greece with 80BHP and 1300Kg.
nick205 - 2/9/09 at 01:08 PM
7 driving in damp/wet conditions is a definite recipe for ring twitter in my experience.
2 people on board does help a little as it holds the back end down more, but then when it does get way from you which it will, the extra weight works against you like a sling shot
Dry miles only for me (unless you get caught out in the rain).
speedyxjs - 2/9/09 at 01:31 PM
My tintop used to spin hugely in the wet with only half throttle so i put wider wheels and tyres on.
The old wheels and tyres are now going on the more powerfull and much lighter locost
StrikerChris - 2/9/09 at 02:32 PM
Thats not so bad then,was just worrying there was something majorly wrong!Just fettling with it if the rain ever holds up!
Chris
britishtrident - 2/9/09 at 02:33 PM
Check the corner weights you have a lot of power but one rear wheel might need more weight jacked on to it.
[Edited on 2/9/09 by britishtrident]
StrikerChris - 2/9/09 at 02:41 PM
The cornerweights were bob on in the final build,and I'd expect the lsd to compensate alittle, but I guess it will have settled,I'll do them again with afew more miles on the clock!
SeaBass - 2/9/09 at 02:47 PM
I went up the power range from xflow 1300, 1600, another more powerful 1600 then onto 2l Zetec on TBs. This helped to control the car but even the old 1300 boat anchor could spin the wheels in 3rd... It the wet unclean roads that do it.
JC
Canada EH! - 2/9/09 at 02:49 PM
Your LSD isn't helping in the wet, locks up and the rear of the car follows the crown in the road, open diff just blows all the excess power out one wheel.
I drive a Jeep Wrangler with a LSD, total hell on ice and snow if the back end breaks loose
Dave Ashurst - 2/9/09 at 04:57 PM
Have you set the dampers too stiff?
Danozeman - 2/9/09 at 05:03 PM
Ther great fun in the wet but also make you poo your pants. Mine snakes the rear in 4th in the wet if the roads are a bit greasy.
coozer - 2/9/09 at 05:22 PM
I have 14 psi in my tyres to try calm the backend.
Will happily snake up the road in 1st, 2nd, 3rd if theres any H2O present.
Chucking into corners, roundabouts are worse the back end comes round with the slightest bit throttle.
ReMan - 2/9/09 at 08:05 PM
And in 6th if I put the power down hard in the wet 1 up
