Although in general pain on my chassis is in good nick, I have a number of small areas where I have rust esp around the areas such as welded joints
and where there has been stone impacts (it was finished in the 90's so the paint has done pretty well!). The plan is to locally clean up these
areas, removing any loose paint and then treat them with POR15 (after degreasing etc).
I am all up for buying tools to help me do this type of nasty jobs. Any suggestion?? As I hope this is a one off so I was thinking of this tool
https://www.amazon.co.uk/Draper-79340-230-Volt-Multitool-Accessories/dp/B000ELJ0HY/ref=pd_ybh_a_2?ie=UTF8&psc=1&refRID=5S0YFJN7G36AXFRE8CGH
I already have a grinder so could buy disks for this if there is anything suitable
Alex
I'd go for a wire wheel or cup brush in a grinder rather than a Dremel.
Hi Slim38, have one of those - thanks!
looking at what I have to clean up around the rear axle trailing arms and other similar areas, the access is not that good and cup brush / wire wheel will not get in there....
I know some people love them but for some reason I have never really got on with my multi tool and it just sits in its box.
As slimy38 says I would use wire wheel or poly abrasive disc if you had enough access.
My choice in restricted access areas is a black and decker rotary file, you can easily fit different grades of sanding belts to it. Although it
probably does need a bit more access than a multitool.
http://www.axminster.co.uk/black-decker-ka900e-powerfile-701847?gclid=CLm0w67Xk84CFQgz0wodDNgOaQ
My choice in restricted access areas is a black and decker rotary file, you can easily fit different grades of sanding belts to it. Although it probably does need a bit more access than a multitool.
the power file looks the business... :-) and will get to most areas. any suggestion of which grit paper to get?
Thanks Slim38!
