Anyone got one gts or similar knocking about?
I don't have one.
Are you wanting one to fit an existing chassis?
Hi
That's my plan.
Little project for winter
Not sure if there's anyone that stocks them "on the shelf", but still commonly used in some racing cars/series.
I'd suspect getting hold of a pre-made one will require a real stroke of luck now that GTS Tuning is no more, and DTR Cars (who took it over)
have done the same.
I'd look up the McSorely build plans (GTS W7DE uses the +442 version), as I think they had the details on them for the manufacture of the DeDion
setup - and have a chat with your local friendly fabricator!
Cheers for the info.
Not a easy as I hoped it would be
Alfa romeos had them in the gtv6 and alfetta.
Hope that helps.
Will have a nose.
Caterham?
https://caterhamparts.co.uk/de-dion-tube/2588-de-dion-tube-narrow-buttress-s3.html
Originally posted by goaty
Hi
That's my plan.
I plan to fabricate all the mounts etc myself so anything the correct width should be possible.
I have been looking at the option of caterham parts too
I wonder if Retro Power would make you one?
I have one I won't be using now, made to accept sierra rear hubs, will come with the 4 trailing arms with bushes and panhard rod too (I will be
keeping the sierra bits)
lots more pics here:
http://www.locostbuilders.co.uk/viewthread.php?tid=208037
U2u sent
