clairetoo
| posted on 22/2/09 at 08:50 PM |
quote: Originally posted by omega 24 v6
From my understanding of it the bigger changes in airflow occur during the fist say 25% of the throttle movement so higher throttle openings would be
OK covered by a bigger gap in the tps bins.
I've done my TPS bins as a curve - very small steps at the start , gradually getting larger .
The first third of the graph covers about the first 10% of throttle opening .
[Edited on 22/2/09 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
omega 24 v6
| posted on 22/2/09 at 08:54 PM |
Yip Claire your confirming my thoughts on the matter.
Big learning curve this squirt thing. Very interesting but also very frustrating at times. well it has been for me at least LOL
flak monkey
| posted on 22/2/09 at 09:04 PM |
This is where I am at the moment. Its not too bad around the cruising areas now, and is getting quite close at WOT too. Obviously needs some smoothing
out though.
Do you think my first TPS bins are too far apart?
[Edited on 22/2/09 by flak monkey]
Sera
http://www.motosera.com
omega 24 v6
| posted on 22/2/09 at 09:18 PM |
Looks not to bad IMHO.
If we agreed on the last couple of posts re the light throttle opening then perhaps you'd need to go on the tps scale something like.
59
62
65
68
72
80
90
110
135
160
180
220
I'm just speculating David and no expert by any stretch of the imagination but it may be worth a try. It'd be the same route I'd be
doing myself when the time comes. You can always go back to where you are now.
ETA oops it's upside down ( i'm sure you noticed though)
[Edited on 22/2/09 by omega 24 v6]
flak monkey
| posted on 23/2/09 at 03:56 PM |
By playing around it looks like mine splutters before it leaves the first TPS bin on the map and the ADC count only increases by 1 point too.
I'll have another play at the weekend and see how I get on
Sera
Meeerrrk
| posted on 23/2/09 at 06:14 PM |
quote: Originally posted by flak monkey
I am not bothered about mpg, i just want it running well. Its not very far out now. If i lean the idle up much more the engine dies under light
throttle, leaning out too far.
Theres little point chucking in more fuel than it needs to produce max power, does more harm than good to the engine and my wallet!
fair enough, just interested where you were coming from thats all
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
sebastiaan
| posted on 24/2/09 at 04:53 PM |
Check for play between the throttle shaft and the TPS sensor. It sounds as though the throttles are opening without actuating the TPS. This would
cause the engine to go lean.
What ignition system are you using? I'm running my MSextra Pinto on the EFI dizzy with an added ignition module (not the TFI unit, that
didn't fit in my chassis due to the car being LHD)
Sebastiaan
