JAG
| posted on 14/4/25 at 11:06 AM |
Returning my Car to the road!
My car has been off the road since I decided, foolishly perhaps, to revamp the Dashboard and re-organise the under-dash wiring.
I registered and began using my car in 2006 and I took it off-road in 2016 and it's now 2025
Initially I missed driving but I enjoyed working on the car again.
The final joblist looks like this...
1) I re-made my throttle pedal to make the car easier to drive - switched from a 'hanging-pedal' to an 'organ-pedal' design
2) I fixed the broken engine mounts and raised the enigine by 25mm to give a bit more road clearance
3) Re-made the dashboard and centre console to make it look nicer, fitted new Racetech instruments and made it easier to get to the wiring etc...
4) Re-wired everything under the Dashboard
5) Moved some controls to the Steering Wheel to make the car easier to drive
6) I put a bulge in the bonnet to clear the raised engine
7) I'm about to replace the fuel tank and fit a new fuel pump and filter
About halfway through that list I lost motivation - I forgot how much fun the car was to drive AND I got fed up with working on it in the garage!
I think that's why it's taken so long to get back to this point. Anyway I'm just waiting on a new fuel tank and then it should be
running and working again.
This site has helped remind me of the good times, when the car was on the road, and to keep me motivated and interested.
I'm going to add a few pictures of what I've done simply to help others facing similar struggles
Throttle Pedal...
Dashboard and wiring...
  8th May 2016 Wiring removed and labelled.
  dashboard blank
  New centre section trial fit
Steering wheel controls...
Bonnet Bulge...
  Annealing ready to be bashed!
  Bulge after 2 hours work
  Bulge after 5 hours work
Fuel tank...
  New fuel tank
The car as it was this weekend...
  1st time out of the garage
[Edited on 14/4/25 by JAG]
Justin
| posted on 14/4/25 at 01:52 PM |
I know the feeling. Mine broke a trailing arm, and despite fixing it promptly, it ended up dead in the garage for 7 years! Now I try to religiously
start it at least monthly. Mot ran out a few months ago and there's a minor list of things I'm working through to get it passed again.
Booked in in ten days time woohoo!
Schrodinger
| posted on 14/4/25 at 04:04 PM |
Keep at it, it will get done and be driven again.
BTW I need a new petrol tank where are you getting your's made?
Keith
Aviemore
JAG
| posted on 14/4/25 at 06:35 PM |
Thanks both
Fuel tank is coming from Alloy Racing Fabrications Ltd: sales@alloyracingfabrications.com
Justin
scudderfish
| posted on 14/4/25 at 07:29 PM |
Did you trace around your own foot?
JAG
| posted on 14/4/25 at 08:20 PM |
erm... maybe
Justin
Mr Whippy
| posted on 18/4/25 at 11:59 AM |
I particularly like how you did the tunnel, looks great. Amazed you hammered out that bonnet bulge! that was so much work but you did it well. Make
sure you use it and take it to some car shows too as their fun.
JAG
| posted on 19/4/25 at 04:12 PM |
Thanks mate, my neighbour wasn’t as impressed with the work on the bonnet! It’s quite a noisy process
Justin
JAG
| posted on 12/5/25 at 08:00 AM |
The new fuel tank has arrived and I've added pictures in my Photo Archive.
There's also a thread here: Fuel Tank Thread with pictures
Justin
