McLannahan
| posted on 14/2/09 at 06:09 PM |
Brake fittings
Hi - I am re-doing the brake lines on my Fury as they take a pretty "special" hand bent route to the rear drums!
It's a 3/16th system I believe and I've bought some pipe benders to make the job look a lot neater.
It's a Mk2 Escort system with rear 8 or 9" drums (one feed is split for the rear drums from the master drum unit).
Photos are on my sparse blog but also here!
http://www.comdiddycom.com/fury/?attachment_id=43
Could anyone clarify what size these unions might be and the best place to buy them cheaply?
Thanks all
Michael
big_wasa
| posted on 14/2/09 at 06:12 PM |
The drums will be m10x1
And you can get a bag full on ebay for a few quid.
McLannahan
| posted on 14/2/09 at 06:22 PM |
Thanks BW! Would the ones on the brake res. be the same too?
Michael
[Edited on 14/2/09 by McLannahan]
big_wasa
| posted on 14/2/09 at 06:36 PM |
should be, but willwood and others are imperial. 3/8.
They also come long and short
McLannahan
| posted on 14/2/09 at 07:19 PM |
Ahh crap, it's never simple is it?
Thanks for your help BW!
bigfoot4616
| posted on 14/2/09 at 08:34 PM |
just been renewing some brake pipes today.
my master cylinder ones where the same as the wheel cylinders, m10.
my setup at the drum was like yours with one side fed from the other and only one bleed nipple, but now i've fitted a three way connector to the
axle and fed both sides separately.
i used the long unions, i don't think it matters as long as they are not to short
Chippy
| posted on 15/2/09 at 12:01 AM |
May be wrong, but wouldn't a Mk2 Escort be pre metric? Cheers Ray
