55ant
| posted on 18/10/09 at 08:27 PM |
Folding nose cone
Been working on the car today and its a right pain in the rse takin the 4 bolts out to remove the nosecone, ive seen a couple of people with folding
nosecoes, and also one completely removeable, looked like it was attatched to the bonnet,
any advice on how either of these can be achieved would be great, cheers,
ant
away from cars, now cycling and building TT bikes
Miks15
| posted on 18/10/09 at 08:39 PM |
i believe some people use a hinge at the bottom of the nosecone on to the lowest chassis rail at the front,
StevieB
| posted on 18/10/09 at 08:48 PM |
I have the same gripes about my car.
My mates Lotus 7 uses Dzus fasteners (as do Caterham, I believe), which I think I might adopt for my car at some point.
tomblyth
| posted on 18/10/09 at 09:03 PM |
I have one bolt at the base of the nose cone and to rubber bonnet catches on the inside edge of the nose , takes seconds to remove ond replace!!
iscmatt
| posted on 18/10/09 at 11:37 PM |
thats what i did, just cheapo
hinges from b&q
dhutch
| posted on 18/10/09 at 11:40 PM |
I have three duzts fasteners.
- Two each side just the bottom of where the the bonnet and one on the bottom edge of the nose.
Doesnt take that long with a 2p peice.
Daniel
pewe
| posted on 19/10/09 at 10:43 AM |
Two small black gate hinge under the nosecone - shortest edges onto the chassis and the longer edges on the nosecone means you can bend the longer
edges to match the nose-cone profile.
Dzus fastener either side on the vertical surface just behind the headlight brackets works for me.
HTH. Cheers, Pewe
Marcus
| posted on 2/11/09 at 07:51 PM |
AS above really, I've used 2 stainless hinges on the lower rail (covered by the number plate). The rear is held down by the bonnet, so no need
for any more fixings. I've also used a tether wire to stop the whole thing flopping too far forwards and wrecking the paint. (guess what made me
do this....)
Marcus
Because kits are for girls!!
