Hi,
I've been trying in vain to find company who can actually manage to match a paint sample accurately! the old car is needing some touch up but
whatever colour they used has not been recorded on the spray shop receipt which was the height of stupidity tbh. There are no codes on the body or VIN
plate.
Thanks.
Can't recommend a colour match service, but is this website any help....?
https://paintref.com/cgi-bin/colorcodedisplay.cgi?year=1938&manuf=
Ford
Any decent paint supplier should be able to offer a range of colour cards you can try against the vehicle, if you have something which can be removed,
I know some of the larger suppliers now have the facility where they scan it to determine the colour & can then give a formula for a match,
unfortunately any paint supplied is only as accurate as the guys who does the mix. I had 2 batches of paint from a local supplier to the same colour
code, but were substantially different.
The smaller the amount they are mixing the less accurate to the genuine mixed colour formulation it's likely to be
Decent paint supplier with a spectrometer and colour match cards
BUT as said above it all depends on the skill of the operator/mixer
Ask at some bodyshops who they recommend. They will know the good ones.
https://paintref.com/cgi-bin/colorcodedisplay.cgi?year=1938&manuf= Ford
Thanks for the help, I've emailed a supplier who claims they can analyse a sample and make a match. Funnily enough they've literally just
replied, they say anything about the size of my hand would be fine and they will return it with the paint, not given me a cost though. I think there
is a bit in the engine bay I could remove and still use the car.
Let that be a lesson when painting your car, pick a common standard colour you can get at any store like Halford.
[Edited on 2/8/23 by Mr Whippy]
It’s not only the colour it’s the different shades in that colour
Take Ford Arizona gold it has 7 different shades from shade 1 to 7 has a big difference in colour
