mikeo632
| posted on 14/8/26 at 08:03 PM |
Lower fron balljoints.
Fitting new lower wishbones & re-engineering the front suspension (previous post), can anyone tell me the distance between the fixings on a Maxi
lower ball joint?
My old lower wishbones ran transit, & the fixings holes on the new wishbones are a different spacing (narrower at 70mm centre to centre), so
can't re-use those, but don't want to order Maxi ones to find they don't fit.
Will the Maxi ones fit?
Thanks.
Myke 2463
| posted on 15/8/26 at 06:48 AM |
Maxi ball joint. Mounting holes centre's 68mm with large hole 41mm .
Be Lucky Mike.
Slimy38
| posted on 15/8/26 at 07:40 AM |
Go to the manufacturer of ball joints, they tend to include schematics for bolt positions etc. Then you will have a part number to match against.
mikeo632
| posted on 15/8/26 at 10:52 AM |
Brilliant, thanks to both, problem answered. :-)
