Iv had a search but can't find what im looking for.
If i have to do any welding to my already powder coated chassis i will obviosly have to rub back the powdercoating where i want to weld... will i be
able to spray paint the newly welded on part with normal car spray paint and get a good blend with the powdercoating or might it have some sort of
reaction and go all manky?
Also on a larger scale if i want to change the colour of my chassis can i paint over powdercoat or would i have to rub down the whole chassis
many thanks
I've never had a problem using plasti-kote satin black (matches my powder coat nicely). I thought the whole thing re powdercoat was that it was fairly inert... I suppose a reaction with some paints is possible...
yes you can paint over it but you need to sand ir first ,if it gets scrached on the way to the job from the powdercoaters the touch it up with
matching paint my mate works at a powder coating place .burn it off and wire brush it thats how to remove it fast.
you could just buy some powder from ebay and redo the bit you welded with a heat gun.
[Edited on 15/1/09 by thunderace]
perhaps powder coat wasn't the best option for you then. Paint will stick to it if you use a good plastic primer.
thats good to know, if i get some powder to match the colour of my chassis how do you put it on with a heat gun... sorry i have no idea
what about repowder coating wheels? if say you want to change the colour...
do they the remove previous coat first or just coat ontop of that?
Plasticote or spray can hammerite smooth works for me.
Think of the powdercoat as plastic, because that's what it is. If the paint will stick to plastic, it'll stick to the powdercoated area.
